Looks good Fran! If I was to cut that pattern, I would of cut the pattern between two panels, essentially shortening the pattern into two manageable sections. Then I would cut the backer board on the table saw. Then glue the two panels to the backer board.
6 hours ago, new2woodwrk said:
Really nice cut! So that was one piece of wood? What kind of wood did you use?
Thanks for sharing it
Thanks Jes! I used 1/4" BB, treated it with Danish Oil then used 2 coats of Minwax Oak Polyshades. The backing is also 1/4" BB painted black. I took the picture before I glued the backing on, they do line up in the finished project.
