cowboyup3371 Posted February 4, 2020 Report Share Posted February 4, 2020 (edited) Please know I tried to search for this first but I think I wasn't using the correct terms so if this has already been answered please let me know where to look Now that I am almost done with the remake of a display case project I messed up on before Thanksgiving, I'm thinking of making some Valentine's Day gifts for my wife and two daughters. As I have a lot of scrap oak, I figured I'd use it up but one of the scroll patterns looked to be larger than some of what I have laying around. Consequently, my first thought was to edge glue two boards to make a wider piece for the pattern. Although I have since decided on a different pattern that will fit what I have much better and still look good (or so I hope ), I am still curious if cutting across a glue joint would cause any problems? Is there anything I should consider before tackling something like that? I know there are a lot out there that say just use plywood but I personally don't care for the look of plywood as the main piece. I'm sure I will change my mind some day but I really do prefer actual hardwood instead and will use plywood as a back or a bottom Edited February 4, 2020 by cowboyup3371 OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
jollyred Posted February 4, 2020 Report Share Posted February 4, 2020 As long as you have a good joint, there is no problem with the cutting. Tom OCtoolguy, dgman and tomsteve 3 Quote Link to comment Share on other sites More sharing options...
dgman Posted February 4, 2020 Report Share Posted February 4, 2020 Ditto on what Tom Said. I glue up boards all the time. You have to have perfectly jointed edges. Fortunately for me, I have a jointer, but can be done with a good table saw blade. As long as the edges are perfectly square and flat, and using wood glue and clamps, you should be good to go! tomsteve and OCtoolguy 1 1 Quote Link to comment Share on other sites More sharing options...
JTTHECLOCKMAN Posted February 4, 2020 Report Share Posted February 4, 2020 I agree 100% too. Nothing wrong with gluing edge to edge if they are jointed properly and use a good quality wood glue such as TitebondII Clamp well but do not over clamp to squeeze all the glue out and starve the joint. I have used glued boards many times. I prefer hardwoods too and use plywoods when needed. OCtoolguy and dgman 1 1 Quote Link to comment Share on other sites More sharing options...
Bill WIlson Posted February 4, 2020 Report Share Posted February 4, 2020 Ditto to all of the above. I would only add that you should examine the grain carefully and try to match the panels up, being especially conscious of how the grain of both pieces flow at the joint. Red oak has wildly different appearances, based on how the boards are cut from the tree. Try to get 2 boards with as similar a grain pattern as possible to help hide the glue joint. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Rolf Posted February 4, 2020 Report Share Posted February 4, 2020 Most of the larger fretwork projects that I have made for SSWWC are all re-sawn, jointed and edge glued. I do slice them a bit thicker and then sand them so that they are perfectly flat. As the others have said the glue joint is a non issue. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
fredfret Posted February 4, 2020 Report Share Posted February 4, 2020 If the joint is well glued, the wood grain matched no problem, poorly done joint well? OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
cowboyup3371 Posted February 5, 2020 Author Report Share Posted February 5, 2020 Thanks all OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
