baggetta Posted February 8, 2020 Report Posted February 8, 2020 Ok, let's have some more compound cutting fun. This is a simple project and produces a little holder for your toothpicks, assuming you have any that need holding. This requires a block 1.5 x 1.5 x 6". Don't actually need 6" but I like to have enough to hold onto at each end when I'm cutting. You'll need a hole down the center of this block, and you can do this with a 1/2" forstner bit, before you make any cuts. I went down about 2/3 rds of the way. Use a skip tooth or crown tooth blade to cut this. I also used a piece of wood cut from a 2 x 4 (nothing fancy). I like the variety of grains that pop out of the center of a 2 x 4. Free Pattern RabidAlien, jollyred, Ninuninu and 1 other 4 Quote
Rockytime Posted February 9, 2020 Report Posted February 9, 2020 Everyone needs a toothpick holder unless one is toothless, that is. Very cool! RabidAlien 1 Quote
amazingkevin Posted February 9, 2020 Report Posted February 9, 2020 Great ideas for scrap pieces! Super idea!!! Quote
