On my Fairly new Dewalt today.That If you have the optional light,When you lift the arm up make sure its away form the light.Melted where the switch is.I only knew when I brought the arm back down and there it was. :oops:
Radhi if you could use a florescent type of blub you wouldn't create as much heat with the bulb. I say "if" because I am not familiar with the type of bulb the socket will accept.
Len
