Here is my new bowl with a few work in progress pictures and the finished bowl.
As you can see in the picture above I used 3/4 in Poplar Plywood and 3/16 Clear Pine and cut strips that were 7/8 wide and 9 in. long.  I decided that the blank was incomplete so I marked halfway on each side and connected the marks.  I cut the corners off and added a 1/4 inch thick padauk strip on each side.  I decided on a simple round bowl cut at 29 degrees left side down.
DW
I have reposted the pictures using an alternative hosting for the images as aparently ImageShack still is infected. Sorry about that
