planeur Posted March 7, 2020 Report Posted March 7, 2020 I made a sanding jig with a remaining melamine board . As you see it work with the Ridgid sander, on which I improved a lot the succion like that ( couple of years ago ) Easy to do and work ! I had everything . Cost : 0$ Thanks again Ronald Walters for the idea! planeur Scrappile, Be_O_Be, OCtoolguy and 2 others 4 1 Quote
OCtoolguy Posted March 7, 2020 Report Posted March 7, 2020 39 minutes ago, planeur said: I made a sanding jig with a remaining melamine board . As you see it work with the Ridgid sander, on which I improved a lot the succion like that ( couple of years ago ) Easy to do and work ! I had everything . Cost : 0$ Thanks again Ronald Walters for the idea! planeur What type of clamp is that that you are using to hold it to the sander table? It has a round rod type of clamp rod? I've not seen one like that. Quote
planeur Posted March 8, 2020 Author Report Posted March 8, 2020 The little rectangular piece on the jig, is almost 1/8 thick, and have 1/4-20 thread and a screw 1/4-20 entering in the black handle and compressed the bar holding the wheel. To bad I don’t have that little piece number, I have a couple of them , but don’t remember where I bought them. But easily you can do one with a piece of metal and a 1/4-20 tap! The jig is from that video. Hope it help you Ray planeur Be_O_Be and OCtoolguy 2 Quote
OCtoolguy Posted March 8, 2020 Report Posted March 8, 2020 (edited) 38 minutes ago, planeur said: The little rectangular piece on the jig, is almost 1/8 thick, and have 1/4-20 thread and a screw 1/4-20 entering in the black handle and compressed the bar holding the wheel. To bad I don’t have that little piece number, I have a couple of them , but don’t remember where I bought them. But easily you can do one with a piece of metal and a 1/4-20 tap! The jig is from that video. Hope it help you Ray planeur No, not that. In 2 of your pics, there is something round on the lower right corner of the table/jig. I figured it must be a clamp to hold the sanding jig to the sanding table. Just wondering what it was. Edited March 8, 2020 by octoolguy Quote
jollyred Posted March 8, 2020 Report Posted March 8, 2020 I have had clamps like that, they are made to fit in a hole in the base of a machine. Haven't seen them used like planeur is doing. If it works, it must be right. Tom planeur and OCtoolguy 1 1 Quote
planeur Posted March 8, 2020 Author Report Posted March 8, 2020 Ray it is exactly as Tom said, it normaly used fot clamping something with a hole, but also as I did with it. I used this clamp on the jig because I nerver use it very much elsewhere ! planeur OCtoolguy 1 Quote
OCtoolguy Posted March 8, 2020 Report Posted March 8, 2020 2 minutes ago, planeur said: Ray it is exactly as Tom said, it normaly used fot clamping something with a hole, but also as I did with it. I used this clamp on the jig because I nerver use it very much elsewhere ! planeur I guess I need to see it from underneath. I can't picture how it works. Duh! I'm slow! Quote
planeur Posted March 8, 2020 Author Report Posted March 8, 2020 (edited) It look like that ! Now you can have a good night ! Edited March 8, 2020 by planeur OCtoolguy and Wilson142 1 1 Quote
OCtoolguy Posted March 8, 2020 Report Posted March 8, 2020 59 minutes ago, planeur said: It look like that ! Now you can have a good night ! I've never seen that before. Thanks. Quote
OCtoolguy Posted March 8, 2020 Report Posted March 8, 2020 What is that device hanging down Les? Looks interesting. Quote
Rockytime Posted March 8, 2020 Report Posted March 8, 2020 It's a watchmaker lathe I swiping it up to use it and it does not taķe up bench space. OCtoolguy 1 Quote
oldhudson Posted March 8, 2020 Report Posted March 8, 2020 Very useful making wooden gears. OCtoolguy 1 Quote
Badgerboy Posted March 8, 2020 Report Posted March 8, 2020 14 hours ago, octoolguy said: What is that device hanging down Les? Looks interesting. I had the same question OCtoolguy 1 Quote
