Multi-Frame Display Project Pattern
baggetta
Ok.  This is a bit of work, but some of you might enjoy tampering with this idea.  This is a little project you might like to make.  I have two patterns in the pattern book: one for a Little Dancer (shown) and one for a Golf Pro, which can be cut on your scroll saw from 1/4" plywood.  I used some scrap I had.  You could make others on various themes if you have the inclination.  The final result is a little box with layered frames which give a 3D effect.  I also lit the box with a free flashlight I picked up at Harbor Freight.  I think these are offered in all their million ads being circulated.  I was able to get different colored effects by using blue, green, or yellow painters tape for a flashlight cover.  Also better filters the light.  If you use this don't leave the light on too long.  Not sure if there is a build up of heat that could burn the tape.  The pattern book has the two patterns you'll need and a sketchy plan for the box and some images of my build.  If you study the patterns you'll get the idea. Available for free on the Free Pattern Page.
