trackman Posted March 17, 2020 Report Posted March 17, 2020 (edited) I got a set of clamps for my EX21 from Denny. Steve Good did a vibration test using a cell phone app. I did the same. With the standard clamps it showed 0.3. With the pegas it showed 0.1. Other things I noticed are the saw is quieter. The tension level works much easier. Not sure if it is my imagination but it seems like I don’t have to hold the wood down to the table as hard. Only negative thing is after 10+ years of putting the blade into the bottom clamp (I top feed) it took a few hole changes to get the “feel” of were the clamp slot is. Really no big deal there. Would I take off a set of good clamps just to go to the pegas clamps? No. But mine was about 6 years old and needed the change. Just my 3 cents worth. Edited March 17, 2020 by trackman amazingkevin, OCtoolguy, Dave Monk and 1 other 3 1 Quote
Denny Knappen Posted March 17, 2020 Report Posted March 17, 2020 Thanks for the good report and glad you received the Pegas Chuck Heads. I agree don't change unless you need to, but if you need to, the Pegas Blade Chuck Heads are a great improvement. scrollingforsanity, OCtoolguy and amazingkevin 3 Quote
Wilson142 Posted March 17, 2020 Report Posted March 17, 2020 I bought a set because Scrappile was looking for another opinion on them from someone who uses spiral blades. My old clamps were (and still are)fine. I bought the set for a Dewalt DW788 and they don't come with the tensioning lever. I see a little less vibration (maybe) and while they are fine clamps, I don't know if I would give them a full vocal recommendation. They were only a bit more expensive that the Dewalt replacement. If I had it to do over, I would have ordered a set with the tensioning lever and hoped they would still fit my Dewalt. From the sounds of reviews on other saws, I think the quick blade change without needing retensioning would be a huge benefit for me because I do mostly fretwork. If I ever see a review from a Dewalt owner who has tried the set with the lever, I would probably consider buying a set. amazingkevin, scrollingforsanity and OCtoolguy 3 Quote
OCtoolguy Posted March 17, 2020 Report Posted March 17, 2020 I bought the first set for my EX21. The old clamps were still in good working order but I liked the simplicity of the Pegas and so I bought a set. I have NO regrets. They gave me less vibration and it's obvious that they are lighter weight. I love how they work too. So effortless and smooth. I DO feel that they are a bit pricey so I still haven't pulled the trigger on another set for my EX16 but at some point, after the world comes back to it's senses, I'll order another set. Maybe by then they will feel that the price is too high and drop it a bit. I know, wishful thinking. scrollingforsanity and amazingkevin 2 Quote
Jim McDonald Posted March 18, 2020 Report Posted March 18, 2020 I bought a set for my Dewalt some time back. I had just replaced the thumb screws earlier that season, but based on a few early reviews, I popped for a set and found the differences worth the cost of the upgrade. Maybe the better bite on the blade or the feeling that top feeding seems faster--but I can't think of putting the factory clamps back on the saw. Yes, I did save them in case. Took me maybe five drill holes to realize i made the right choice. OCtoolguy, scrollingforsanity and amazingkevin 3 Quote
scrollingforsanity Posted March 18, 2020 Report Posted March 18, 2020 I have a set of Pegas clamps on my EX21 and my Seyco. I have had them on my Seyco and EX for a year and would not go back to the old ones unless the Pegas broke and I had to wait until new ones arrived. Very smooth and easy to operate. I'm sold! OCtoolguy and amazingkevin 1 1 Quote
Wilson142 Posted March 18, 2020 Report Posted March 18, 2020 10 hours ago, Jim McDonald said: I bought a set for my Dewalt some time back. I had just replaced the thumb screws earlier that season, but based on a few early reviews, I popped for a set and found the differences worth the cost of the upgrade. Maybe the better bite on the blade or the feeling that top feeding seems faster--but I can't think of putting the factory clamps back on the saw. Yes, I did save them in case. Took me maybe five drill holes to realize i made the right choice. Which set did you buy? Did you buy the set with the tensioning lever or the other? OCtoolguy 1 Quote
Jim McDonald Posted March 18, 2020 Report Posted March 18, 2020 4 hours ago, Wilson142 said: Which set did you buy? Did you buy the set with the tensioning lever or the other? Just bought the regular Dewalt clamps. Just like the factory, but red and solid. OCtoolguy and Wilson142 2 Quote
OCtoolguy Posted March 18, 2020 Report Posted March 18, 2020 If I had bought the Pegas for my Dewalt, I was going to buy the Pegas design. I figured that the tension slider on the Dewalt was basically the same as the black knob on the EX's so I would just move it to about half way and leave it there and do all the tensioning with the Pegas white lever. I'm sure there must be folks who have done this. Wilson142 1 Quote
Roberta Moreton Posted March 18, 2020 Report Posted March 18, 2020 I put a set on the Dewalt. The recommendation is to buy just the Dewalt style clamp. Use the regular Dewalt tensioner. It works great. OCtoolguy and Jim McDonald 1 1 Quote
OCtoolguy Posted March 18, 2020 Report Posted March 18, 2020 3 hours ago, Roberta Moreton said: I put a set on the Dewalt. The recommendation is to buy just the Dewalt style clamp. Use the regular Dewalt tensioner. It works great. I was going to do as I said because I liked that way of tensioning and would not have to worry about which saw I was using and how to tension. The muscle memory would not have to learn and remember two different things to do the same job. amazingkevin 1 Quote
Roberta Moreton Posted March 19, 2020 Report Posted March 19, 2020 But it works different on the Dewalt. I don’t see how it would function right. The tension is applied from the back on my EX correct? and from the front on the Dewalt. OCtoolguy 1 Quote
don in brooklin on Posted March 19, 2020 Report Posted March 19, 2020 22 minutes ago, Roberta Moreton said: But it works different on the Dewalt. I don’t see how it would function right. The tension is applied from the back on my EX correct? and from the front on the Dewalt. The tension on the EX-21 is not applied from the back. See link for explanation https://www.scrollsawvillage.com/forums/topic/37709-a-couple-of-blade-questions/#comment-417328 Quote
Frank Pellow Posted March 19, 2020 Report Posted March 19, 2020 On 3/17/2020 at 9:27 PM, Jim McDonald said: … Took me maybe five drill holes to realize i made the right choice. It took you as many as five holes? I knew after one hole after replacing the clamps on my EX-30 that I had made the right choice. JimErn and scrollingforsanity 1 1 Quote
OCtoolguy Posted March 19, 2020 Report Posted March 19, 2020 5 hours ago, Roberta Moreton said: But it works different on the Dewalt. I don’t see how it would function right. The tension is applied from the back on my EX correct? and from the front on the Dewalt. No, the tension is applied from the front on both saws. The black knob is NOT for tensioning. It's only there to adjust the arm. On the Dewalt I would set the tension full ON or at a point that allowed the blade to be installed as far as length would permit. Then actually apply the tension with the lever on the top clamp. If you think about it on the Dewalt the tension lever does the same thing as the EX/Pegas. It sets the arm height. So once it's set, leave it there and apply tension with the lever. scrollingforsanity and Wilson142 2 Quote
Gonzo Posted March 20, 2020 Report Posted March 20, 2020 I've had my Pegas clamps on my EX -21 for a couple of months. Nothing was wrong with original clamps, but Denny had the Pegas on sale so I thought what the hell, why not. Was money well spent. OCtoolguy, amazingkevin and scrollingforsanity 2 1 Quote
BadBob Posted March 21, 2020 Report Posted March 21, 2020 Maybe it is my imagination, but with the Pegas Clamps, my EX21 seems to cut better and faster, and the blades last longer. amazingkevin, scrollingforsanity and OCtoolguy 2 1 Quote
OCtoolguy Posted March 21, 2020 Report Posted March 21, 2020 4 hours ago, BadBob said: Maybe it is my imagination, but with the Pegas Clamps, my EX21 seems to cut better and faster, and the blades last longer. I don't think it's your imagination. scrollingforsanity 1 Quote
amazingkevin Posted March 22, 2020 Report Posted March 22, 2020 Can't wait for Santa to send me some! OCtoolguy and scrollingforsanity 1 1 Quote
Gonzo Posted March 22, 2020 Report Posted March 22, 2020 I agree with Ray, I don't think it's your imagination. scrollingforsanity and OCtoolguy 2 Quote
Frank Pellow Posted March 22, 2020 Report Posted March 22, 2020 21 hours ago, octoolguy said: I don't think it's your imagination. Nor do I. scrollingforsanity and OCtoolguy 2 Quote
iScroller Posted March 23, 2020 Report Posted March 23, 2020 Anyone with Pegas clamps on a Jet 22"? OCtoolguy 1 Quote
