applying shellac by hand is a problem. Try rattle can shellac and don't touch until completely dry.
I use Sherwin Williams Chem Aqua Plus lacquer via air spry gun and don't touch the pieces until dry.
I lay the puzzle pieces on bump-ons in a strip of wood 3" x 4'. The piece of wood rests on a lazy susan device so it can be rotated with ease to coat all ends and a surface.
After the initial coat is dry, I will flip the pieces and recoat the edges and the uncoated surface. I do all of this outside on a deck.
Unfortunately the Sherwin Williams product only comes in a gallon - no rattle cans.
You might consider a water based sealant made by Deft that comes in a rattle can.
https://www.amazon.com/Deft-Interior-Water-Based-11-25-Ounce-Aerosol/dp/B0017OKFQ2
bb
Edited by puzzleman
clarification
bb
I have tried the Deft water based lacquer and didn’t like it at all!
10 hours ago, new2woodwrk said:
However, I notice before applying Shellac the color comes off onto my fingers.
You may not be letting the dye get dry enough before you touch it when you get it ready for the shellac.  Maybe use the rubber gloves when you touch the pieces.  Maybe you need to rub the pieces down with a rag to remove any residue that is there?
Larry
