I cut it using 3/4" poplar. No problems with it. The ears were not a concern to me, but there are a few cuts deep into some of the bodies that had me concerned. In the end, there were no issues.  The hardest part for me were the small eyes. I dropped down to a #1 MGT blade to cut the eyes. Everything else was cut with a #5.
I haven’t cut it yet but I have the pattern mounted and ready to cut sometime this week. With anything I cut, if necessary, I will adjust as I’m cutting. If something looks fragile, I’ll either not cut it as the pattern says, or cut it differently. I’ve been cutting over twenty years, I know what will be sturdy or not. In my opinion, Aspen is too soft a wood, which will make close cuts fragile.
I wanted to send this to my Grandkids and am recutting it using Red Oak and modifying the pattern.
There is one place where a wide ear goes down to a little less than 3/16" where it goes into the head and is weak.  Another place a leg goes down to 1 /8" where it meets the body. I will widen these out to strengthen them.  I also am going to shorten so of the detail cuts in places.
It is very cute puzzle!
Ingenuity will work I promise you. I learned this lesson from Steve Good along time ago.if the cut gets to hard don,t go so close. And the pattern I remember I had a problem with in my early days was Micheal Jackson on his tip toes from Steve Good and it worked. His legs gave me the problem long skinny cuts next to each other up and down. I laugh at that problem now,lol
I'd think red oak would be another wood i wouldn't use.. as red oak likes to break easily along the grain.. while easy to glue since it usually breaks along the grain it hides the glue line easily.. I've used red oak in some questionable projects.. I also carefully place the pattern so that the fragile parts wouldn't be along the grain lines which helps tremendously.. I'd use Poplar, cherry or maple for something like this I think..
16 hours ago, Sycamore67 said:
Has anyone cut the Bunny Pile.  It is really cute but it is very fragile.  Several of the areas of the ears are quite thin and fragile.  I cut one from Aspen which is not very strong and cut in the lines and had ears break.  I am recutting it from Red Oak and will redesign a couple areas near some ears.
where can I find the pattern?
bb
