scrollerpete Posted March 23, 2020 Report Posted March 23, 2020 Just got back from Florida for 3 months, back in my shop in the basement and my EX16 seems to have developed quite a bit of front to back movement from the blade. I think since I left her alone for 3 months she decided to punish me. Did not have time to read on it yet but since I have to be quarantine for another 8 days, it will give me lot’s of time to figure it out. OCtoolguy, scrollingforsanity, romka555 and 1 other 2 1 1 Quote
OCtoolguy Posted March 23, 2020 Report Posted March 23, 2020 20 minutes ago, scrollerpete said: Just got back from Florida for 3 months, back in my shop in the basement and my EX16 seems to have developed quite a bit of front to back movement from the blade. I think since I left her alone for 3 months she decided to punish me. Did not have time to read on it yet but since I have to be quarantine for another 8 days, it will give me lot’s of time to figure it out. The only thing that could happen is if the motor bolts came loose. That's where you adjust the aggressive cut. scrollingforsanity 1 Quote
scrollerpete Posted March 23, 2020 Author Report Posted March 23, 2020 Will get at it tomorrow, first make sure that the arm is parallel and then move the motor back and forth. OCtoolguy and scrollingforsanity 2 Quote
OCtoolguy Posted March 23, 2020 Report Posted March 23, 2020 12 minutes ago, scrollerpete said: Will get at it tomorrow, first make sure that the arm is parallel and then move the motor back and forth. Yes, I forgot about the arm. You didn't pick the saw up by the arm did you? That's a definitie NO NO. scrollingforsanity 1 Quote
scrollingforsanity Posted March 24, 2020 Report Posted March 24, 2020 I had some trouble with my Seyco recently. I finally found the culprit, the four screws ( two on each side top and bottom ) on the front of the arm one side has the hold down foot attached. They were all loose and actually lost one of them. The bottom four were loose as well letting the linkage work loose in the arms. Went to the hardware store and got a new screw, tightened up the others and she was back in running condition. Checked my EX as well but they were tight as I had taken it apart before and must have cranked them down tight. Moral of story it doesn't take much to throw the saw a bit out of whack. OCtoolguy and Scrappile 2 Quote
OCtoolguy Posted March 24, 2020 Report Posted March 24, 2020 2 hours ago, scrollingforsanity said: I had some trouble with my Seyco recently. I finally found the culprit, the four screws ( two on each side top and bottom ) on the front of the arm one side has the hold down foot attached. They were all loose and actually lost one of them. The bottom four were loose as well letting the linkage work loose in the arms. Went to the hardware store and got a new screw, tightened up the others and she was back in running condition. Checked my EX as well but they were tight as I had taken it apart before and must have cranked them down tight. Moral of story it doesn't take much to throw the saw a bit out of whack. Maybe a drop of blue LocTite is called for. scrollingforsanity 1 Quote
scrollerpete Posted March 24, 2020 Author Report Posted March 24, 2020 16 hours ago, octoolguy said: Yes, I forgot about the arm. You didn't pick the saw up by the arm did you? That's a definitie NO NO. No this saw stayed in my shop in the basement, I have another one that I bring with me in Florida OCtoolguy 1 Quote
scrollingforsanity Posted March 24, 2020 Report Posted March 24, 2020 That's possible Ray. They have stayed tight so far. I keep checking them. I think they must not have been really tight when I purchased the saw. OCtoolguy 1 Quote
scrollerpete Posted March 24, 2020 Author Report Posted March 24, 2020 All is well, loosen the motor’s screws and fine tune it, had to move it about 1/4”. Now let’s get some projects done, still have 8 days left of self isolation. meflick and scrollingforsanity 2 Quote
