Since Easter is coming and most of us are trapped in our social distancing environments, I thought it might be fun to experiment with a bunny pencil topper.  I designed the head so that it can be compound cut on the scroll saw.  I did mine on a 1.5 x 1.5 x 3" block cut from a 2 x 4.  This soft pine is easy to cut using a #4 skip tooth blade.  After you cut your block, x out a center on the end and drill a 5/16" hole about an inch into the block on the end.  This will be the hole in the head for the pencil.  Now you can do a plain ol' compound cut.  If you are new to compound cutting check out my Spinner video on YouTube
Free Pattern
WHATSSSS Up Doc"!        Neat!      The repl thng s not workng rght at all
Edited by rjR
typo Trying to get used to the new hit the return and automatically posts it---& the reply thing is just not working right. At first I tholught that it was my keybaord quitting, but it works fine everywhere else!
