new2woodwrk Posted April 6, 2020 Report Posted April 6, 2020 I have a few patterns I want to stack cut but not sure if I should use 1/4 or 1/8" BB? How do you decide which to use. Here is an example of what i want to cut this week Thoughts? Thanks as always in advance scrollingforsanity and OCtoolguy 1 1 Quote
New Guy Posted April 6, 2020 Report Posted April 6, 2020 Looks like 1/8' to me. OCtoolguy, scrollingforsanity and new2woodwrk 2 1 Quote
fredfret Posted April 6, 2020 Report Posted April 6, 2020 If you're using a backer 1/8 if not 1/4. Do you have a need/use for more than two copies. I usually cut 3 if using 1/8 just a habit gives a little more support. OCtoolguy and new2woodwrk 2 Quote
new2woodwrk Posted April 6, 2020 Author Report Posted April 6, 2020 16 minutes ago, fredfret said: If you're using a backer 1/8 if not 1/4. Do you have a need/use for more than two copies. I usually cut 3 if using 1/8 just a habit gives a little more support. Not really a need or use, more of a "If I'm going to cut something like this, I want to maximize my output and get as many as possible out of it." That way, I have for gifts and samples etc. Both would get a backer and frame OCtoolguy and scrollingforsanity 2 Quote
JimErn Posted April 6, 2020 Report Posted April 6, 2020 1/8th, and do a stack of 3 or 4, I use an PMG # 3 for most everything and certainly for this OCtoolguy, new2woodwrk and scrollingforsanity 1 2 Quote
crupiea Posted April 6, 2020 Report Posted April 6, 2020 For me it depends on the complexity of the cuts. The thicker the piece the more washed out the complex cuts will be just due to the size. I use 1/8" bb. scrollingforsanity, new2woodwrk and OCtoolguy 1 2 Quote
MrsN Posted April 6, 2020 Report Posted April 6, 2020 I would use 1/8" because that is what I have on hand. new2woodwrk, scrollingforsanity and LarryEA 2 1 Quote
kmmcrafts Posted April 7, 2020 Report Posted April 7, 2020 I cut everything from 1/8" and stack cut between 4-6 at a time.. Of coarse I'm a seller so the more I do in one cutting helps keep the price down.. Only 1/4" I use is backers for the most part... That said.. most backers are a contrasting ( usually walnut ) 1/4" plywood material... not much for BB backers and stained.. I guess that method doesn't float my boat... but to each their own.. new2woodwrk 1 Quote
Scrappile Posted April 7, 2020 Report Posted April 7, 2020 I use both. Has to do with type of picture and size. Lot of fine veining, I like to use 1/8" because thicker and the veining will not show up. I erred on my last picture, well didn't err, I didn't have a piece of 1/8" so I used 1/4". As you can see the detail of the picture does not show up like it would have had I used 1/8". On bigger detailed pictures it may not matter as much. new2woodwrk 1 Quote
