edward Posted March 14, 2011 Report Posted March 14, 2011 Have a question, on printing patterns, everytime I down load a pattern and save it to my computer, and then try to print it, it comes up bad quality, am I doing something wrong. Any help accepted. Edward Quote
Messman Posted March 14, 2011 Report Posted March 14, 2011 The first thing I would check the next time you try to print another pattern is to check what setting you have the printer set to print at. Do you have it set for draft, standard etc. I would make sure that it is set to at least standard. If you still are getting a poor quality print, then check the level of your ink. If you have enough ink then I am not sure what the problem is. But at least this is a place to start. Quote
amazingkevin Posted March 14, 2011 Report Posted March 14, 2011 hi Edward,I right click on a pattern and chose ,the open link, that makes for a clearer pattern to copy for me.Allso depending where the pattern is ,if it's in ssv then i'll open the pattern up twice,to get the largest pattern to copy.hope this helps, not sure if this is the problem for you. Quote
mikesscrollsaw Posted March 14, 2011 Report Posted March 14, 2011 Make sure you open it up as large as possible. If you save a small picture the quality won't be good. Quote
