cashew Posted April 16, 2020 Report Posted April 16, 2020 (edited) Finally complete but for lacquer -- This is all Baltic Birch cut with a #1 modified geometry Pegas blade on a Pegas scroll sawFrom the ground up --There is a 1/4 backer with 3/4 added for a border (the blue)- then white letters are cut in 3/8 -- the black letters in 1/4 -- the gray and white border on the triangle is one layer 1/4 (gray 1/4 across) and one of 1/4 on top (white 1/8 across centered on the gray.The eagle is 1/2 mounted on a 1/8 backer mounted on the large backer of 1/8 and shaped with a Dremel edit : for some reason it reversed the order of pictures and I can't seem to fix it Edited April 16, 2020 by cashew namunolie, Dave Monk, heppnerguy and 2 others 5 Quote
Tomanydogs Posted April 16, 2020 Report Posted April 16, 2020 I absolutely love what you’ve done. Everything looks sharp and crisp. Wonderfully done!!! I didn’t know that you could shape plywood and it would look that good. cashew and amazingkevin 1 1 Quote
cashew Posted April 16, 2020 Author Report Posted April 16, 2020 6 minutes ago, Tomanydogs said: I absolutely love what you’ve done. Everything looks sharp and crisp. Wonderfully done!!! I didn’t know that you could shape plywood and it would look that good. I once made plywood from 1/4 cedar planks and then carved with a dremel -- If you watch close while doing it you can make it work for you amazingkevin and ChelCass 2 Quote
Tomanydogs Posted April 16, 2020 Report Posted April 16, 2020 1 minute ago, cashew said: I once made plywood from 1/4 cedar planks and then carved with a dremel -- If you watch close while doing it you can make it work for you That’s also very pretty. I want to give it a try. Does it separate and break easily on the edges? cashew 1 Quote
wombatie Posted April 16, 2020 Report Posted April 16, 2020 That is an awesome project and whoever receives it will be blown away by it. Very well done. Marg cashew 1 Quote
amazingkevin Posted April 16, 2020 Report Posted April 16, 2020 10 hours ago, cashew said: I once made plywood from 1/4 cedar planks and then carved with a dremel -- If you watch close while doing it you can make it work for you Your inspiring me to get going on something new and nice seeing your work here!!!! cashew 1 Quote
cashew Posted April 16, 2020 Author Report Posted April 16, 2020 (edited) 12 hours ago, Tomanydogs said: That’s also very pretty. I want to give it a try. Does it separate and break easily on the edges? I usually used a sanding drum for the most part -- but I did use a Kutzall on the bow -- the glue line transitions can be a bit rough if you don't clamp it tight enough while gluing the layers together -- the planks are very dry but they can have some amazing color -- The bow and feathers were 4 layers and the flower was 6 layers -- all alternating the grain direction -- the big feather was just a single plank Edited April 16, 2020 by cashew Tomanydogs 1 Quote
heppnerguy Posted April 16, 2020 Report Posted April 16, 2020 amazing signs. I love your work and are so happy you posted it so others could also enjoy what you do Dick heppnerguy cashew 1 Quote
