Popular Post amazingkevin Posted May 15, 2020 Popular Post Report Posted May 15, 2020 Repeat customer now wants an outside version of the same. Lucky me the Marine Carpenters threw away P.T.3/4"x2"x8' long pieces cut from many big wide boards. So right away I knew this will work for her. I hand planned the front and sanded, the back just sanded.will 123 zinzeer primer sealer tomorrow .thanks for looking 2' x15' glued with titebond 2 glue.W-E-E-T-R & P were cut with a spiral as I couldn,t urn the 2' wood. Loskoppie, Dave Monk, New Guy and 13 others 16 Quote
Dragonkort Posted May 16, 2020 Report Posted May 16, 2020 woundeful work!!! it looks great!!! I use both the regular blades and spirals for that very reason and because its sometimes just easer to not have to turn the wood in tight corners. amazingkevin 1 Quote
amazingkevin Posted May 16, 2020 Author Report Posted May 16, 2020 1 hour ago, Dragonkort said: woundeful work!!! it looks great!!! I use both the regular blades and spirals for that very reason and because its sometimes just easer to not have to turn the wood in tight corners. I agree!!! Thank you for looking Dragonkort!!! Quote
Dragonkort Posted May 16, 2020 Report Posted May 16, 2020 lol I like looking but now my computer times up so ttul amazingkevin 1 Quote
amazingkevin Posted May 16, 2020 Author Report Posted May 16, 2020 7 minutes ago, Dragonkort said: lol I like looking but now my computer times up so ttul Ya,LL come back when you get time!!! Thank you Dragonkort Quote
wombatie Posted May 16, 2020 Report Posted May 16, 2020 Look good. Well done Kevin. Marg amazingkevin 1 Quote
woodduck Posted May 16, 2020 Report Posted May 16, 2020 Good work Kev, especially cutting some of the letters with spirals. amazingkevin 1 Quote
don watson Posted May 16, 2020 Report Posted May 16, 2020 Well done Kevin. I sometimes use spirals for the same reason. amazingkevin 1 Quote
amazingkevin Posted May 16, 2020 Author Report Posted May 16, 2020 12 hours ago, Rockytime said: Very nice Kevin! It was a nightmare to glue up 16 thin warped sticks but I gott it done. Thanks Les. Think I,LL upgrade my homemade glue up table as I can see improvements!!! Quote
amazingkevin Posted May 16, 2020 Author Report Posted May 16, 2020 8 hours ago, wombatie said: Look good. Well done Kevin. Marg Experience is the best t Quote
amazingkevin Posted May 16, 2020 Author Report Posted May 16, 2020 8 hours ago, wombatie said: Look good. Well done Kevin. Marg Experience is the best teacher. I,ve little experience gluing so I,m learning from my mistakes,lol Thank you Marg!!! Quote
amazingkevin Posted May 16, 2020 Author Report Posted May 16, 2020 6 hours ago, woodduck said: Good work Kev, especially cutting some of the letters with spirals. Thanks wood duck,I like spirals and enjoyed the change for just a few letters!!! Quote
amazingkevin Posted May 16, 2020 Author Report Posted May 16, 2020 4 hours ago, don watson said: Well done Kevin. I sometimes use spirals for the same reason. Yes sir!!! Good thing they make spirals or else what,lol Thank you Don!!! Quote
amazingkevin Posted May 16, 2020 Author Report Posted May 16, 2020 2 hours ago, daveww1 said: very nice job Ah hah!!! You did a fine inspection job again,Dave!!! Thank you!!! Quote
spirithorse Posted May 17, 2020 Report Posted May 17, 2020 Nice work, Kevin! I just cut a pattern that was too large to turn on my saw but, instead of resorting to spirals (which I knew would end up being a disaster) I just drilled entry holes on the top of the letters and at the bottom of the letters so that I could cut part way around in a clockwise direction and then half way around in a counter clockwise direction to complete the cut, That worked out well for me with this particular project. Also, a member of Scrollsaw Woodworking and Crafts magazine mentioned years ago that on occasion, he put the blade in his saw backwards so that he could pull the wood toward him to cut rather than pushing to wood back toward the throat. I have used that on occasion also but, must really go slow and carefully because it is uncomfortable. You know what I mean, just not the way we have trained our minds to do things. God Bless! Spirithorse don watson, amazingkevin and John B 2 1 Quote
meflick Posted May 19, 2020 Report Posted May 19, 2020 Awesome work there Kevin. Sure your repeat customer will be back for more projects. amazingkevin 1 Quote
amazingkevin Posted May 20, 2020 Author Report Posted May 20, 2020 On 5/16/2020 at 10:30 PM, spirithorse said: Nice work, Kevin! I just cut a pattern that was too large to turn on my saw but, instead of resorting to spirals (which I knew would end up being a disaster) I just drilled entry holes on the top of the letters and at the bottom of the letters so that I could cut part way around in a clockwise direction and then half way around in a counter clockwise direction to complete the cut, That worked out well for me with this particular project. Also, a member of Scrollsaw Woodworking and Crafts magazine mentioned years ago that on occasion, he put the blade in his saw backwards so that he could pull the wood toward him to cut rather than pushing to wood back toward the throat. I have used that on occasion also but, must really go slow and carefully because it is uncomfortable. You know what I mean, just not the way we have trained our minds to do things. God Bless! Spirithorse I tryed the blade backward years ago and it was a disaster.i just wanted it done so extra holes ment extra work so I settled for the infamous spirals. They sure work muscles that have not been used and arm tiring too. Thanks for looking!!! Quote
amazingkevin Posted May 20, 2020 Author Report Posted May 20, 2020 On 5/18/2020 at 8:30 PM, Dave Monk said: Great job Kevin! Thank you Dave ,somemore video,s by you would be nice!!! Thanks friend!!! Quote
amazingkevin Posted May 20, 2020 Author Report Posted May 20, 2020 On 5/18/2020 at 10:39 PM, Ron Johnson said: Well done Kevin. Thank you Mr. Johnson!!! Quote
amazingkevin Posted May 20, 2020 Author Report Posted May 20, 2020 On 5/19/2020 at 12:05 PM, Danj84 said: Well done it looks great Thank you Daniel!!! Danj84 1 Quote
