OCtoolguy Posted May 19, 2020 Report Posted May 19, 2020 After all the talk regarding bandsaws recently, I thought I'd ask a question in a new topic. I have a Delta 28-206 band saw and I'm thinking about adding the 6" riser block to it. I found this one from Woodstock and I was wondering if anybody on SSV has ever bought/installed one of them on a Delta saw. I think the only real difference in any of the blocks offered by different suppliers is the pin/pin hole locations. I don't see that it would be too difficult to redrill the holes but I thought I'd ask here first. The price is far better than buying the Delta unit. Thanks for any and all advice. Quote
Roberta Moreton Posted May 24, 2020 Report Posted May 24, 2020 I have absolutely NO experience. That said, If I was modifying my tool I would buy the product from the manufacturer for ease of support. OCtoolguy and Jim Finn 2 Quote
amazingkevin Posted May 24, 2020 Report Posted May 24, 2020 Good question. I'm getting very interested in band saws lately.Don't know about yours but all the tips and tricks I find on band saws are worth reading and doing. Simple placement of the teeth in the center of the top wheel gets accurate cuts, for one. OCtoolguy 1 Quote
DME72 Posted May 24, 2020 Report Posted May 24, 2020 ray, from what i have read online on other forums is it will fit, but the dowel pin holes may not line up. everything else should fit. a friend who is now gone had the riser block in his delta saw. i never felt like it could properly tension a blade. i dont know if the saw flexed or what. i never could do real well resawing with his saw. this is why i am looking for a new or used bandsaw that will only be set up to resaw. IIRC there was something about the bolt being a smaller size on the riser kit and you would have to buy a larger bolt and nut and washers. for me i am going to buy a resaw bandsaw and keep my delta 14 inch for cutting other stuff with smaller blades. doug OCtoolguy 1 Quote
OCtoolguy Posted May 25, 2020 Author Report Posted May 25, 2020 2 hours ago, DME72 said: ray, from what i have read online on other forums is it will fit, but the dowel pin holes may not line up. everything else should fit. a friend who is now gone had the riser block in his delta saw. i never felt like it could properly tension a blade. i dont know if the saw flexed or what. i never could do real well resawing with his saw. this is why i am looking for a new or used bandsaw that will only be set up to resaw. IIRC there was something about the bolt being a smaller size on the riser kit and you would have to buy a larger bolt and nut and washers. for me i am going to buy a resaw bandsaw and keep my delta 14 inch for cutting other stuff with smaller blades. doug I barely have room for what I have Doug. No room for a second bandsaw. Or the budget. But, things might be changing. We are thinking hard about moving to Knoxville area. If that happens it will open up many possibilities. Fingers crossed! John B, DME72 and tomsteve 3 Quote
DME72 Posted May 25, 2020 Report Posted May 25, 2020 ray, good luck with the move if that happens. we did that 5 years ago and i dont want to do it again! only plus side was i found stuff i thought was lost for good! tomsteve and OCtoolguy 2 Quote
kmmcrafts Posted May 25, 2020 Report Posted May 25, 2020 I know I have read where the riser blocks will work from one saw to the next other than the pins as mentioned above.. Here all the talk of resawing and me saying I don't do it.. well with all the lock down crap and my lumber store closed.. Just last week I had two orders for a clock that I make out of thin stock so I had to set up the saw for resawing.. It is certainly nice to have the ability to resaw in a pinch.. and it got me thinking.. I don't use very much thin stock like I used to so that really is the bigger reason I don't resaw.. though it does take time.. especially if you have to keep changing from one set-up to the next... OCtoolguy 1 Quote
Woodmaster1 Posted May 28, 2020 Report Posted May 28, 2020 I don't know about the riser. But unless your going to resaw often you more than likely not need the extra height. I have a dedicated bandsaw and rarely saw more than 6" for resawing. The only time I have used the full capacity was to cut logs in half for bowl blanks. OCtoolguy 1 Quote
Rockytime Posted May 28, 2020 Report Posted May 28, 2020 Wow, that is one chunk of wood! I don't re-saw and cannot as I have no place to do it. I do find the subject interesting. OCtoolguy 1 Quote
kmmcrafts Posted May 28, 2020 Report Posted May 28, 2020 (edited) Probably going to depend upon what you are making.. But I have resawn 8 - 10 inch more times than 6 inch or less.. Now.. That said.. the majority of resawing for me.. you are correct.. 6" is quite common for scroll work.. and typically just a good re-saw blade and a fence is all that one would need.. I've mentioned it before but I used to resaw with a small 9" ryobi saw that the max height was only like 4.5 inch.. worked perfect for ornaments and small things.. When I bought my setup it was because of several Cherry trees on my property was in the way of the power lines and they needed to come down.. Power company took them down and cut them up into 3 - 4 ft. length.. I resawed a whole lot of that wood much like George shows in his photo.. After that was gone.. I pretty much buy most my lumber close to size and then plane to what I use.. BUT.. if I do need a 1/4" board.. I do re saw it if the saw is set up.. otherwise the time to set it up is not worth it to me so i just waist it into sawdust and plain it to what I need.. I rarely use thin wood unless it's plywood these days.. I find the thin stuff just setting around cups and warps before I get it use it.. so if I'm messing with solid wood it I try to resaw and use it within a few hours.. otherwise for me.. ply works better.. Most my stuff is 5/8 - 3/4 though.. other than ornaments.. which I now make from ply.. It seems that 6" max is always just shy of what you need but rarely ever need more than 7-8" LOL.. Too bad you can't get a 1-2" riser for less money, LOL Edited May 28, 2020 by kmmcrafts Quote
Rolf Posted May 28, 2020 Report Posted May 28, 2020 (edited) I re-saw all the time and I have A delta 28-475X that I added the riser to many years ago. I am surprised that you found a riser. I frequently cut up to 12". It has a 1.5 HP. Of course the alignment is critical. How much more is the Delta unit? It might be worth the extra so that you don't have to mess with it. If you don't get the alignment right by drilling the holes off location you have just wasted your $90 investment. Just comparing pictures of the Delta Vs the one you are looking at the pin locations look the same. What is their return policy if it doesn't fit? Edited May 28, 2020 by Rolf OCtoolguy 1 Quote
OCtoolguy Posted May 28, 2020 Author Report Posted May 28, 2020 6 hours ago, Rolf said: I re-saw all the time and I have A delta 28-475X that I added the riser to many years ago. I am surprised that you found a riser. I frequently cut up to 12". It has a 1.5 HP. Of course the alignment is critical. How much more is the Delta unit? It might be worth the extra so that you don't have to mess with it. If you don't get the alignment right by drilling the holes off location you have just wasted your $90 investment. Just comparing pictures of the Delta Vs the one you are looking at the pin locations look the same. What is their return policy if it doesn't fit? I haven't gone that far yet Rolf. All of a sudden, my mind has had to switch gears. We have decided to buy a motorhome and we are looking at relocating so I'm in a different mode now. scrollingforsanity 1 Quote
Rolf Posted May 28, 2020 Report Posted May 28, 2020 Where are you thinking of going? OCtoolguy 1 Quote
OCtoolguy Posted May 28, 2020 Author Report Posted May 28, 2020 22 minutes ago, Rolf said: Where are you thinking of going? Eastern Tennessee. Around the Knoxville area. Quote
rjweb Posted May 28, 2020 Report Posted May 28, 2020 Ray, you lucky dog, good luck with the move, RJ OCtoolguy 1 Quote
OCtoolguy Posted May 29, 2020 Author Report Posted May 29, 2020 36 minutes ago, rjweb said: Ray, you lucky dog, good luck with the move, RJ This will be our last adventure. We are very long in the tooth but can't stand it here in California any longer. It's just out of control. And living is so much cheaper in other places. We'll never have to pay rent again. We can buy a nice home on property for what our mobile home is worth here. Crazy! Quote
Dave Monk Posted May 29, 2020 Report Posted May 29, 2020 34 minutes ago, octoolguy said: This will be our last adventure. We are very long in the tooth but can't stand it here in California any longer. It's just out of control. And living is so much cheaper in other places. We'll never have to pay rent again. We can buy a nice home on property for what our mobile home is worth here. Crazy! Why Knoxville? Not too long ago I was thinking it was Oklahoma. OCtoolguy 1 Quote
Rockytime Posted May 29, 2020 Report Posted May 29, 2020 Well Ray, wherever you end up I wish you and yours all the happiness in the world. Quote
tgiro Posted May 29, 2020 Report Posted May 29, 2020 Ray -- If you're moving to Knoxville, you won't be far from Judy Gale Roberts. Maybe it's time for you to learn intarsia. Quote
OCtoolguy Posted May 29, 2020 Author Report Posted May 29, 2020 35 minutes ago, Dave Monk said: Why Knoxville? Not too long ago I was thinking it was Oklahoma. Our closest friends moved to Norman, Ok. We went to visit them last October. Thanks but no thanks. We are heading to Tennessee because we have quite a few friends who have moved there over the last few years. Everything we hear about their experiences is leading us in that direction. I heard many years ago about a family who moved to Bristol and absolutely loved it. Then our neighbors retired about 5 years ago and moved there and bought an old home on 11 acres. They now have a small farm with all the animals. That's not for us. We just want to settle down in a real house with a garage and a little ground to park our RV on. I'll build a shop and everything will be wonderful. Until it's not! Lol. Dave Monk and Rolf 2 Quote
Woodmaster1 Posted May 29, 2020 Report Posted May 29, 2020 You will not like Tennessee because your commute from home to anywhere won't be long enough to remind you of California. My daughter has lived in Fayetteville area for several years and it is a beautiful state. Good luck on your move! OCtoolguy 1 Quote
OCtoolguy Posted May 29, 2020 Author Report Posted May 29, 2020 2 hours ago, Woodmaster1 said: You will not like Tennessee because your commute from home to anywhere won't be long enough to remind you of California. My daughter has lived in Fayetteville area for several years and it is a beautiful state. Good luck on your move! We came to the realization that great weather is not worth all of the stuff that is wrong. Quote
tomsteve Posted May 29, 2020 Report Posted May 29, 2020 if yer using it for resawing, i think you should purchase this one: https://woodmizer.com/Store/Shop/Resaws-Bandsaws/HR130-Resaw-Bandsaw then move within 30 miles of me. i might even offer free labor. OCtoolguy and kmmcrafts 2 Quote
kmmcrafts Posted May 29, 2020 Report Posted May 29, 2020 20 minutes ago, tomsteve said: if yer using it for resawing, i think you should purchase this one: https://woodmizer.com/Store/Shop/Resaws-Bandsaws/HR130-Resaw-Bandsaw then move within 30 miles of me. i might even offer free labor. I almost did that on one of the other bandsaw topics, LOL OCtoolguy 1 Quote
kmmcrafts Posted May 29, 2020 Report Posted May 29, 2020 Ray, I don't blame you for the move.. I could never make it in CA with all the rules etc they have, LOL I also have to say if you locate to TN I be jealous, LOL My wife and I both say if we ever was to move it be TN area where we'd go.. I wish you much happiness and a nice roomy shop where ever you end up at.. Quote
