cashew Posted May 19, 2020 Report Posted May 19, 2020 (edited) Here's the completion of that experiment -- I did some more shaping with the Dremel and then applied Danish oil. For those of you wanting to know how -- I'll get it down better but here's the nutshell version -- cut the bowl as you normally would -- then the top layer gets cut on the same line , but both angled in and out, then sanded down to about 1/2 it's original thickness . It seems to work best on thicker wood (tried on 3/8 baltic and failed miserably). Once I get it down I'll try to get more detailed than that . I did end up with a crack in this one because when I went to glue the base on it slid sideways but i didn't catch it for about an hour. I separated it again (cracking it) and re-glued. I'll be trying it again shortly , only larger. Edit -- I forgot to add -- the top ring was cut at 40 degrees outward and 30 inward the next was cut at 22 1/2 - the next at 15 - all on 4/4 black limba -- I may revise those angles on the next one Edited May 20, 2020 by cashew jollyred, Wilson142, Loskoppie and 5 others 7 1 Quote
Rockytime Posted May 20, 2020 Report Posted May 20, 2020 That's an impressive work of art. cashew 1 Quote
amazingkevin Posted May 20, 2020 Report Posted May 20, 2020 Whoa! The nutcracker suite!!! cashew 1 Quote
munzieb Posted May 20, 2020 Report Posted May 20, 2020 Amazing project. A real eye catcher! cashew 1 Quote
Dragonkort Posted May 20, 2020 Report Posted May 20, 2020 fantastic!!! that is just beautiful!!! cashew 1 Quote
