cashew Posted May 25, 2020 Report Share Posted May 25, 2020 I'm re-doing the little flower bowl in a larger size and this time I took some progress pics that may help you see the method I came up with. In the first pic I've already done the outside cut at 40 degrees angled outward and set up for the next cut - this time at 35 degrees inward on the same line. The second pic shows that cut complete. From there I dropped the angle by 5 degrees per cut -- starting at the beginning it's 40 - 35 - 30 - 25 - 20 - then 15 for the final cut (the base). You do have to adjust the cut lines as you go inward or you won't end up with enough glue surface --each layer needed re-drawn as I went -- I feel like there may be a smoother way to do it but I haven't found it yet (maybe reverse the cut order and start at the base?). Also sanding the sides can be scary as some of the wall areas are thinner than I'd like because of the angle changes - especially in the 5 corners -- In these pics nothing is glued to together yet -- it would almost look cool to leave the outside like this and just smooth out the inside but we'll see next time. barb.j.enders, Rockytime, jollyred and 6 others 8 1 Quote Link to comment Share on other sites More sharing options...
rjR Posted May 25, 2020 Report Share Posted May 25, 2020 Lots of work. Looking Great too. cashew 1 Quote Link to comment Share on other sites More sharing options...
amazingkevin Posted May 26, 2020 Report Share Posted May 26, 2020 Your working on being the best darn bowl maker soon!!! cashew 1 Quote Link to comment Share on other sites More sharing options...
cashew Posted May 26, 2020 Author Report Share Posted May 26, 2020 55 minutes ago, amazingkevin said: Your working on being the best darn bowl maker soon!!! Thanks but with this wood it would be hard to do a really bad piece -- even mistakes look good amazingkevin 1 Quote Link to comment Share on other sites More sharing options...
daveww1 Posted May 26, 2020 Report Share Posted May 26, 2020 looking forward to seeing the finished bowl cashew 1 Quote Link to comment Share on other sites More sharing options...
Dragonkort Posted May 26, 2020 Report Share Posted May 26, 2020 now that is wounderful work!!! and im glad you added the pictures for those of us who need pictures to help make things clearer for us!!! its something I wouldn't mind trying but I could never figure out the math !!! I cant wait to see the finished bowl either. cashew 1 Quote Link to comment Share on other sites More sharing options...
