I’m having trouble with my saw and can’t figure it out. I have my speed set, and while cutting, the speed picks up and then slows back down. Almost like if you where in a car, hit the gas, and let off the accelerator. I don’t use a foot petal, so that’s not the issue. Please, let me know if you have any ideas.
I have had the same issue with my EX-21. The first time it happened I removed the top plastic piece and checked for lose parts. Didn’t find anything so put the plastic top on again. Saw ran normally for quite a while. When it happened again, I blew compressed air into the space by the top arm. Saw settled down again. I found if I ran it at full speed it generally pulsated, so I always ran it at a little under full.
The saw was practically brand new when I bought it, after a while it seemed to break in, and I could run it full speed if I wished and it would act fine. Not sure how new your Jet is, but it could just need broken in.
Like new saw said, maybe needs to be broke in, but before I take a stab at it, does the acceleration occur when your not cutting wood? Also, does it occur at different speeds like that? I don’t own a Jet, but these are an attempt to isolate the problem. I have a Dewalt 788 Type 1 and I can run it at any speed without any problems. Just my two cents.
