OzarkSawdust Posted June 12, 2020 Report Posted June 12, 2020 On the King, Pegas, etc., etc. clones the air blower tube comes off a metal ball and is a multi jointed plastic thing. How do you get it to stay put on the metal ball??? Anyone have problems with it staying where you adjust it? OCtoolguy 1 Quote
LarryEA Posted June 12, 2020 Report Posted June 12, 2020 The connection from the to the metal ball is loose. Because the connector to the ball has a slight crack in it and that makes it loose. Pop the one off and use the next one OzarkSawdust, crupiea and OCtoolguy 1 2 Quote
bandaideman Posted June 12, 2020 Report Posted June 12, 2020 I have done the above and helped with Dewalt but with the Ex 21 it was just plan loosey goosey and I used a little red loc tite and it is working great so far. OzarkSawdust and OCtoolguy 1 1 Quote
dgman Posted June 12, 2020 Report Posted June 12, 2020 As Larry mentioned, the first link is cracked. Heat it with a heat gun or hair dryer and pop it off. Then heat the next one and pop it back on. Blow on it to cool it off and presto, it’s just like new! OCtoolguy, OzarkSawdust and LarryEA 1 2 Quote
Trka2002 Posted June 12, 2020 Report Posted June 12, 2020 I just fixed mine Monday. Pop the first piece off and stick it back on. If it’s like mine, it will go back on hard. OzarkSawdust and OCtoolguy 1 1 Quote
crupiea Posted June 13, 2020 Report Posted June 13, 2020 if you dont have a heat gun, boil some water and dip the tube in that for a minute or two. it will loosen up enough to work. It will be hotter than hell so wear gloves or something. Sort of happens when you dip stuff in boiling water but of course I have to learn stuff the hard way. John B and Rockytime 1 1 Quote
kmmcrafts Posted June 13, 2020 Report Posted June 13, 2020 My EX-21 is just starting to do this as well... I remember doing this many times with my old DeWalt.. the tube got to a point where it was getting too short to do much good.. I sold it before actually having to replace some of the hose.. I have seen where others have added a hose shoved up inside the flex hose to add length to it.. I always used the boiling water to heat it.. ( didn't have a heat gun at the time ) and I also would use a drop of dish soap to help slide the thing back onto the metal part.. I'm not certain it helped though as being in hot water and then wet still and then adding soap made the thing hard to hold onto while trying to push it back on.. I believe there is a special tool for doing those things.. but I've always been able to get it with hot and soapy, LOL OzarkSawdust 1 Quote
BadBob Posted June 15, 2020 Report Posted June 15, 2020 Loc-Line makes a clamp for tighting these. crupiea and OzarkSawdust 2 Quote
OzarkSawdust Posted June 16, 2020 Author Report Posted June 16, 2020 (edited) I pulled the old one off, grabbed end piece with pliers and pulled off the rest. Then heated the next one with a heat gun and pushed it on. After the heat gun it went on easy...letting it cool now. Didn't work...as soon as I touched it...it fell down. I wonder if super glue would work. Edited June 16, 2020 by OzarkSawdust Quote
kmmcrafts Posted June 16, 2020 Report Posted June 16, 2020 59 minutes ago, OzarkSawdust said: I pulled the old one off, grabbed end piece with pliers and pulled off the rest. Then heated the next one with a heat gun and pushed it on. After the heat gun it went on easy...letting it cool now. Didn't work...as soon as I touched it...it fell down. I wonder if super glue would work. could it be wrapped with black electrical tape? I guess super glue might work as well but I'd be afraid of it not coming off if / when you might need it to.. Quote
OzarkSawdust Posted June 17, 2020 Author Report Posted June 17, 2020 I wonder about a couple of drops of Lock Tight...? That might come off easier than Super Glue. Quote
ozzyoz Posted June 26, 2020 Report Posted June 26, 2020 I just used a standard hose clamp, worked a treat Quote
Fedido Posted June 27, 2020 Report Posted June 27, 2020 On 6/13/2020 at 9:08 AM, kmmcrafts said: My EX-21 is just starting to do this as well... I remember doing this many times with my old DeWalt.. the tube got to a point where it was getting too short to do much good.. I sold it before actually having to replace some of the hose.. I have seen where others have added a hose shoved up inside the flex hose to add length to it.. I always used the boiling water to heat it.. ( didn't have a heat gun at the time ) and I also would use a drop of dish soap to help slide the thing back onto the metal part.. I'm not certain it helped though as being in hot water and then wet still and then adding soap made the thing hard to hold onto while trying to push it back on.. I believe there is a special tool for doing those things.. but I've always been able to get it with hot and soapy, LOL Yes, there is a special tool...a hammer, the. Paint to match! OzarkSawdust and kmmcrafts 2 Quote
kmmcrafts Posted June 27, 2020 Report Posted June 27, 2020 9 hours ago, Fedido said: Yes, there is a special tool...a hammer, the. Paint to match! The small hammer or the bigger 5 lb hammer.. OzarkSawdust 1 Quote
OzarkSawdust Posted June 30, 2020 Author Report Posted June 30, 2020 I ended up putting a couple drops of blue Locktight ( the cheep generic one) on it, worked it in a little, and out a prop on it (after I set the right spot) to dry overnight. I was VERY careful making a small adjustment...and so far it works great! I'm being extra cautious to not bump it! We'll see how long it lasts before I use a couple more drops. kmmcrafts and crupiea 2 Quote
