Popular Post Rockytime Posted June 18, 2020 Popular Post Report Posted June 18, 2020 Don from Brooklyn in Ontario provided me with this pattern. What I love about his patterns is the thin red outline with a light green fill. Makes cutting a real pleasure. The plaque is 14" X 5" X 1/2" oak. #1 PMG with 50/50 BLO. I nearly screwed up the edges on the router. My router is just a 1/4" trim router on a very makeshift table. The vertical adjustment is very crude and it was set too deep causing the router to bog down. I should have made a couple of shallow cuts then a finish cut. Worked out eventually. Still needs a backer and a couple of coats of poly semi gloss to finish. meflick, namunolie, JimErn and 12 others 15 Quote
wombatie Posted June 18, 2020 Report Posted June 18, 2020 Looks good Les, well done. Marg Rockytime 1 Quote
spirithorse Posted June 19, 2020 Report Posted June 19, 2020 Nice work, Les and a great pattern @don in brooklin on God Bless! Spirithorse Rockytime 1 Quote
amazingkevin Posted June 24, 2020 Report Posted June 24, 2020 Amazing quality Rockytime!!! No sand baging around you get the job done!!! Rockytime 1 Quote
