Popular Post munzieb Posted June 20, 2020 Popular Post Report Posted June 20, 2020 Recent rainy weather held me off from assorted outdoor projects so I decided to cut a project I had in my pattern library for quite a while. It's a narrow fret box made from Bubinga 10 x 4.5". Original pattern had straight sides and I decided to add furniture style feet. A little tricky cutting these small parts but I got it done. meflick, OzarkSawdust, Be_O_Be and 17 others 19 1 Quote
Badgerboy Posted June 20, 2020 Report Posted June 20, 2020 Wow Bernd that is beautiful and impeccable cutting. I hope you are well and happy Father’s Day! munzieb 1 Quote
dgman Posted June 20, 2020 Report Posted June 20, 2020 Beautiful box Bernd! It’s been a while since I’ve cut a project like that. munzieb 1 Quote
munzieb Posted June 20, 2020 Author Report Posted June 20, 2020 1 hour ago, Badgerboy said: Wow Bernd that is beautiful and impeccable cutting. I hope you are well and happy Father’s Day! Thanks Todd, hope you are doing well also. Fret work is always attractive but when cutting 14 of the same pattern it can get a little repetitive. Even though the feet are small, they were more challenging to design and cut. The top is a little warped and I may have to revisit the hinges to work the alignment. Quote
Dave Monk Posted June 20, 2020 Report Posted June 20, 2020 A lot of work in that box. Looks great! I sure dislike trying to hinge a box that way. munzieb 1 Quote
munzieb Posted June 20, 2020 Author Report Posted June 20, 2020 Thanks Dave. I've got the hinge thing down pat. I posted my technique in an earlier post but 2 sided tape makes it easy. I'll mark off the outside edges of the hinge on the lower base. The hinges I use are 1/8" thick at the hinge. I actually mounted the lower hinge before I glued the box together, that way I can do all my cuts on the scroll saw. I cut down the 1/8" on the sides and trim out the recess for the hinge. I use the 2 sided tape to hold the hinge in place and drill out for the screws. I'll pre tap the screws with wax and remove the screws. Next, I assemble the sides. I remove the tape on the lower hinge and replace with a smaller piece. I put a piece of 1/16" wood inside the sides of the hinge so that it stands flush and then apply a full size piece of 2 sided tape on top of that. I'll properly position the box frame on top box top and make sure the tape on the top of the hinge adheres to the box top. I use an exacto knife to lift the hinge off the base. They will be properly aligned and I pre drill the mounting screws making sure it doesn't go all the way through by marking the drill with blue tape. I will pre tap the holes with wax. Since the top is 1/4" and screws are 1/4". I'll hold the screw with a vice grip and grind them down to the right size to fit. This actually goes pretty quick once you do it a few times. I've also done this with piano stop hinges also. Quote
meflick Posted June 20, 2020 Report Posted June 20, 2020 What a stunningly beautiful box you have crafted. I am always in awe of you folks who do that intricate fretwork. munzieb 1 Quote
Oges Posted June 20, 2020 Report Posted June 20, 2020 Beautiful looking box, nicely done munzieb 1 Quote
Rockytime Posted June 21, 2020 Report Posted June 21, 2020 I love fretwork but I don't think I have the patience or endurance to attempt that project. I have to say it appears to be worth the effort as it is gorgeous. Very nice! munzieb 1 Quote
wombatie Posted June 21, 2020 Report Posted June 21, 2020 Well it was time well spent. Very impressive looking box, well done. Marg munzieb 1 Quote
Tomanydogs Posted June 21, 2020 Report Posted June 21, 2020 That’s a gorgeous box. And you executed it beautifully . munzieb 1 Quote
daveww1 Posted June 21, 2020 Report Posted June 21, 2020 fantastic job, that box is beautiful munzieb 1 Quote
Scrolling Steve Posted June 21, 2020 Report Posted June 21, 2020 That is great...what a nice piece of work ! munzieb 1 Quote
Dragonkort Posted June 21, 2020 Report Posted June 21, 2020 totaly fantastic!!! wow dosnt do it justice you did such a great job on that!!! munzieb 1 Quote
Newsawontheblock Posted June 22, 2020 Report Posted June 22, 2020 Very nice! What type of finish? munzieb 1 Quote
munzieb Posted June 22, 2020 Author Report Posted June 22, 2020 7 hours ago, Newsawontheblock said: Very nice! What type of finish? Base coat shellac and 3 coats spray gloss lacquer. Newsawontheblock 1 Quote
Ron Johnson Posted June 22, 2020 Report Posted June 22, 2020 Awesome fine work Bernd. munzieb 1 Quote
amazingkevin Posted June 24, 2020 Report Posted June 24, 2020 Dead ringer for getting compliments and smiles. You gave it you all!!! munzieb 1 Quote
ike Posted January 16, 2021 Report Posted January 16, 2021 I LOVE FRETWORK NEVER DID MANY BOXES. LOTS OF SHELVES AND PICTURES. THAT ONE LOOKS LIKE A LOT OF HOLDE . yOU DID A WONDERFLUL JOB ON THAT ONE. ike Quote
