1 hour ago, Hudson River Rick said:
Sorry, I don't have a name to address you by, but you did an outstanding job on those nite lights.  Are they your patterns or are they available somewhere?  I think I would like to try something like these.
Thanks for sharing.
Rick
I got it from pinterest, adjusted it a bit, en looked for a wallpaper on internet.
i then used a battery operated ledstrip.
the square frames are two picture frames glued together.
the round ones are stack cut.
the patterns (on pinterest or Google) are silhouette, so just type in: cat silhouette for example and you get loads.
hope this helps a bit.
They are brilliant.  What do you use for the colored backing?  It would have to be reasonably thin I think to allow the light to shine through.
Marg
Marg
Its not shining through, its a photo, i put a led strip between the front en the back, i put 5 pieces of wood between the front and back.
So the ledstrip reflects the photo.
hard to explain (iam Dutch)
I do understand, thanks.
Marg
19 hours ago, flarud said:
I like the Mermaid one.  Is the ring of LED's on the backside of the first piece of wood.. between the first and second piece?
Thanks!
no its on the side of the circles, somewhat in the middle.
i made a ring/circle thats smaller then the other ones, so  the led strip is somewhat hidden.
bit hard to explain since iam dutch :)
