Popular Post Foxfold Posted August 7, 2020 Popular Post Report Posted August 7, 2020 Never having had the pleasure of cutting 1/8th Baltic Birch before, I bought some and this is the first thing I've ever done with it. OzarkSawdust, danny, jollyred and 14 others 17 Quote
rjweb Posted August 7, 2020 Report Posted August 7, 2020 Beautiful very nice cutting, RJ Foxfold 1 Quote
munzieb Posted August 7, 2020 Report Posted August 7, 2020 Your cutting came out great! I cut a lot of 1/8" BBPW and I always make sure to sand both sides before I start cutting. Sometimes there are loose fibers that can be pulled up when you remove the pattern. Even thin plywood can be hard on blades because of the glue. They dull fast and break but you can make very fine cuts with the smaller blades. Foxfold and amazingkevin 1 1 Quote
amazingkevin Posted August 7, 2020 Report Posted August 7, 2020 Famous good one nice cuts!!! danny and Foxfold 1 1 Quote
meflick Posted August 8, 2020 Report Posted August 8, 2020 Beautiful piece Brenda. Now it’s time to try stack cutting. Foxfold 1 Quote
Jim McDonald Posted August 8, 2020 Report Posted August 8, 2020 Good looking work. Now build a stack of 4 to 6 pieces and crank out some ornaments. Foxfold 1 Quote
wombatie Posted August 8, 2020 Report Posted August 8, 2020 That is a beautiful job Brenda. Well done. Marg Foxfold 1 Quote
don watson Posted August 8, 2020 Report Posted August 8, 2020 Great cutting Brenda. You should find laserply a bit easier to cut than regular ply as it uses water based glue. When I laser burn it goes through this 3mm in just 2 cuts. Again, very good cutting. Don W Quote
Foxfold Posted August 8, 2020 Author Report Posted August 8, 2020 (edited) 3 hours ago, don watson said: Great cutting Brenda. You should find laserply a bit easier to cut than regular ply as it uses water based glue. When I laser burn it goes through this 3mm in just 2 cuts. Again, very good cutting. Don W Oooh, is there a difference ? I thought BB plywood was BB plywood .. I hope you're right cos I got a box full I have googled it and the 'difference' is in the glue !! Edited August 8, 2020 by Foxfold don watson 1 Quote
daveww1 Posted August 8, 2020 Report Posted August 8, 2020 it's beautiful, fantastic job Foxfold 1 Quote
smitty0312 Posted August 8, 2020 Report Posted August 8, 2020 Beautiful cut!! I really that!!.......A+ Foxfold 1 Quote
don watson Posted August 9, 2020 Report Posted August 9, 2020 Every day is a school day Foxfold 1 Quote
namunolie Posted August 10, 2020 Report Posted August 10, 2020 Personally, I think it's cooler when the black part is big awesome Foxfold 1 Quote
GusGustin Posted August 11, 2020 Report Posted August 11, 2020 WOW .. that's great !!!! Foxfold 1 Quote
