Foxfold Posted August 13, 2020 Author Report Posted August 13, 2020 16 minutes ago, don watson said: 'Yellow Pack' is Niqua It is a pack of Niqua Don, but I think it's a 'mixture' of sizes and I already have 144 #3/0 OCtoolguy 1 Quote
redwine Posted August 13, 2020 Report Posted August 13, 2020 I am in total agreement with the majority about not using a 3/0 blade while cutting a single thickness of 1/8 inch bb ply! Also the opening of the hole in the table top is another consideration as to the tear out. Than again as has been stated, it could be a poor quality of bb ply. Search the web or depending where your home is, look up various blade sellers for smaller size, 2/0, 1/0 and work with those. Also you have stated you have not tried stack cutting, this is very easy to do and for a sample cutting just take a couple of small pieces of 1/8 inch bb put some 2 sided tape on 2 sides, press together put a pattern on as you usually do, drill the necessary holes, feed the blade through, select the speed you are comfortable with and start cutting. This works great for cutting ornaments and if you do craft shows, a great way to cut the one pattern and have multiple item to sell or as gifts if not into craft shows. Erv OCtoolguy and Foxfold 1 1 Quote
loftyhermes Posted August 13, 2020 Report Posted August 13, 2020 9 hours ago, Foxfold said: Thanks Steve, however, I've looked everywhere for a 2/0 blade and can't find any. I usually use Niqua. Brenda, if you want to stick with Niqua and buy in the UK then try Original Marquetry, http://www.originalmarquetry.co.uk/category_Fret_Saw_Blades_1.htm they have a wide range but postage could be expensive. or HegnerUK, https://www.hegner.co.uk/products/spares-accessories/scrollsaw-bla or Hobbies sell 2/0 blades but are out of sock in the gross bundle. https://www.hobbies.co.uk/tools/power-tools/yellow-label-fretsaw-b I have used all 3 but have settled with HegnerUK for the time being. If you don't mind buying from the USA then Mikes Workshop, they're called Flying Dutchman blades but are in fact Niqua blades renamed by Mike Moorlach for the American market. https://mikesworkshop.com/collections/blades OCtoolguy 1 Quote
Foxfold Posted August 13, 2020 Author Report Posted August 13, 2020 1 hour ago, loftyhermes said: I have used all 3 but have settled with HegnerUK for the time being. Ok, thanks. I get mine from Hegner too but they don't have any WAIT .. Apparently they now use the name Pebeco/Niqua, as apparently, do Original Marquetry. Well don't you just learn something new every day. So I've ordered a gross from Hegner. John B and OCtoolguy 2 Quote
loftyhermes Posted August 14, 2020 Report Posted August 14, 2020 Brenda, yes Niqua give their blade types names, such as Pebeco are standard non reverse teeth, Speed are reverse tooth blades etc. I now mainly use the Speed blades unless I'm cutting something that doesn't warrant the reverse cut, ie. compound cutting, or metal and plastics. A 2012 Niqua catalogue in PDF form you can have a look at. Niqua_Katalog_Holzlaubsaegen.pdf OCtoolguy and Foxfold 1 1 Quote
amazingkevin Posted August 14, 2020 Report Posted August 14, 2020 I would sandwich it between some other wood to help . Foxfold and OCtoolguy 1 1 Quote
David Helmanson Posted August 15, 2020 Report Posted August 15, 2020 you sure that is Baltic birch not just birch plywood ,,, were did you buy that at hope not a box store ... you need to find a cabinet shop or similar place it usually come in 5 foot by 5 foot sheets ... birch plywood will do that.... never had the russian baltic birch do that OCtoolguy 1 Quote
Foxfold Posted August 15, 2020 Author Report Posted August 15, 2020 37 minutes ago, David Helmanson said: you sure that is Baltic birch not just birch plywood ,,, were did you buy that at hope not a box store ... you need to find a cabinet shop or similar place it usually come in 5 foot by 5 foot sheets ... birch plywood will do that.... never had the russian baltic birch do that Mmm it was advertised as BB. but to be fair it was also sold as BB Laserply. I liked the idea of a 'different' less toxic glue. OCtoolguy 1 Quote
David Helmanson Posted August 16, 2020 Report Posted August 16, 2020 never heard of laser ply .. but no matter what wood you use it all come with a warning on the saw dust is harmful to your health ... so you will figure out just like i did in the beginning what is good and what is not for fret work ... good luck and scroll on .. OCtoolguy 1 Quote
KennyHopkins Posted November 17, 2020 Report Posted November 17, 2020 That is some bad tear out.. all the above suggestions are great.. but I have simply coated the back side of bad bb with some tongue oil and it helped me through the cut. OCtoolguy and Foxfold 1 1 Quote
