I have been wanting to do this for a while.  I had a blue Elvis record in my shopping cart a few months back but never pulled the trigger.  I assume that you had wood on both sides of it as you were cutting?  What blade did you use?
pegus nr.3 reverse skipp.
i sandwiched it between two sheeds of wood, but today i cut 3 records without wood, and its cuts great, just slow down the speed.
I have cut sseveral records. I stack ar least 2 holding them with tape useing a #3 blade of your choice brand. run it slow .I use them as Clocks. they are slow sellers, but they do sell. I have dropped them and they didn't break, They are a lot stronger than you think. Yours look good snd will sell if you make them into a clock. That is a good design for a music room or a teen agers room.
IKE
