Nice work.  I'm curious, looking at the pic of the "L" how big was the bit you used to drill a hole for the blade and where did you drill it so it doesn't show along the edge of the cut somewhere?
I ordered a pin chuck for my drill as it wont close down enought to tighten on my very small bits.  I'm guessing you use a bit that is no larger than the blade kerf itself?
Thanks
Edited by FrankEV
Oh that,s easy! Real close to the part I,LL cut out as all I want is the negative!!! Thanks Frank!!!
