kardar2 Posted April 15, 2011 Report Posted April 15, 2011 Hello I have used Birch plywood from lowes a couple of times and really got frustrated with chip out and then I heard to use high quality wood so I am going try it again so my question to you Pros should I use Ultra Reverse FD blades? I will be using 1/8 " wood thanks Quote
mikesscrollsaw Posted April 15, 2011 Report Posted April 15, 2011 Yes definetly get the better birch plywood. The b/bb wood doesn't have the voids like the plywood you'll find at lowes. As for blades I have used scroll reverse and ultra reverse blades. I like both but think I'm going to stick with the UR blades. I use them not only with Baltic birch ply but on all types and really like them. Quote
andy chew Posted April 16, 2011 Report Posted April 16, 2011 I'VE USED AND HAVE ALL OLSON AND FD BLADES. I HAVE LEARNED DIFFERENT SAWS, WOOD TYPES, AND PEOPLE LIKE DIFFERENT BLADES. IN ONE PROJECT I MAY USE UP TOO 4-5 DIFFERENT BLADES JUST LIKE A PAINTER USES BRUSHES. TRY ONE OR TWO BLADES ON SCRAP SEE WHAT WORK BEST, BUT REMEMBER TOMORROWS A NEW DAY THE BLADE YOU LIKE TODAY YOU MAY HATE NEXT WEEK ON A DIFFERENT PROJECT OR DIFFERENT SAW! I HAVE ALWAYS HAD ISSUE WITH PLYWOOD, MOISTURE OF THE WOOD CHANGES ALOT AND FAST CAUSING CHIPPING OR THE BEST PIECE EVER. I MAINLY USE SOLID HARDWOOD THAT I LAMINATE MY SELF SO I KNOW THE QUALITY AND HAVE LESS CHIP OUT. BUT JUST ABOUT ALWAYS USE A REVERSE CUT BLADE HOPE THIS HELPS ! GOOD WOOD AND BLADES MAKES GOOD WORKS OF ART Quote
kardar2 Posted April 16, 2011 Author Report Posted April 16, 2011 Thanks. For the advise and like you I use hardwood Igor real tired of pine breaking Quote
