Oli69 Posted August 31, 2020 Report Share Posted August 31, 2020 hi guys, how do you manage to finish an item with no lumpy bumpy saw lines ? OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
OCtoolguy Posted August 31, 2020 Report Share Posted August 31, 2020 52 minutes ago, Oli69 said: hi guys, how do you manage to finish an item with no lumpy bumpy saw lines ? Not sure what you mean. Pics? Quote Link to comment Share on other sites More sharing options...
fredfret Posted August 31, 2020 Report Share Posted August 31, 2020 Hand sand OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
new2woodwrk Posted August 31, 2020 Report Share Posted August 31, 2020 4 hours ago, Oli69 said: hi guys, how do you manage to finish an item with no lumpy bumpy saw lines ? A few pics would sure help. However, are you describing the edges of a cut? If I'm not mistaken, that is usually caused by starting and stopping during a cut. In other words, not cutting smoothly. Used to happen to me quite a bit when I first started. Otherwise, not sure what you are referring to... Need pics. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Oli69 Posted September 1, 2020 Author Report Share Posted September 1, 2020 I think you may have answered my question, so basically don't stop and start cut in one line, thank you. Heres a pic anyway. OCtoolguy, new2woodwrk and John B 3 Quote Link to comment Share on other sites More sharing options...
new2woodwrk Posted September 1, 2020 Report Share Posted September 1, 2020 5 hours ago, Oli69 said: I think you may have answered my question, so basically don't stop and start cut in one line, thank you. Heres a pic anyway. That's what I thought. Yes, happened to me quite a bit. Still does once in a while just not as much. Others much more experienced than I will probably chime in at some point - lots of great people/cutters here with years of knowledge to share! Sanding will fix that and get the "bumps" out Thanks for sharing OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Paladin Posted September 1, 2020 Report Share Posted September 1, 2020 smooth cutting is definitely the answer. Try to make cuts like this in one continuous motion. Every time you stop and start, you will leave a mark - especially if you have to reposition your hands. Look at a cut like this before you start feeding into the blade and put your hands in a position where you can continue the cut in one motion - sometimes I have to start with my hand/arm twisted a little bit in preparation for a long curve. The less you have to move your hands around, the better your results will be. Oh - and lots of practice will help too new2woodwrk and OCtoolguy 1 1 Quote Link to comment Share on other sites More sharing options...
Oli69 Posted September 1, 2020 Author Report Share Posted September 1, 2020 Thank you for you answers, hopefully the next one will be better new2woodwrk and OCtoolguy 2 Quote Link to comment Share on other sites More sharing options...
OCtoolguy Posted September 1, 2020 Report Share Posted September 1, 2020 15 hours ago, Oli69 said: I think you may have answered my question, so basically don't stop and start cut in one line, thank you. Heres a pic anyway. It looks like you are "chasing" the pattern line. Try not to do that. Just keep cutting and if you veer off the line gradually bring the blade back on to the line. Once the pattern is removed, nobody but you will know that it was altered a bit. Something we've all had to learn. new2woodwrk 1 Quote Link to comment Share on other sites More sharing options...
kmmcrafts Posted September 1, 2020 Report Share Posted September 1, 2020 Pushing slightly from one side or the other rather than straight on can do this too.. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
Rockytime Posted September 2, 2020 Report Share Posted September 2, 2020 The thicker the wood the more likely it will happen. You certainly aren't the first. OCtoolguy 1 Quote Link to comment Share on other sites More sharing options...
carl1 Posted September 2, 2020 Report Share Posted September 2, 2020 On 9/1/2020 at 12:51 AM, Oli69 said: I think you may have answered my question, so basically don't stop and start cut in one line, thank you. Heres a pic anyway. Mine is just as good as yours. Thanks for posting, that helps. Carl Quote Link to comment Share on other sites More sharing options...
