NC Scroller Posted September 12, 2020 Report Posted September 12, 2020 On 9/11/2020 at 8:37 AM, BadBob said: The Klingspor sanding mop is a great tool. I learned real quick the t I needed to run it at slow speed. I use it so much that it is almost always on the drill press. I have a similar setup but I have mine mounted in a mini lathe. new2woodwrk 1 Quote
Rockytime Posted September 13, 2020 Report Posted September 13, 2020 3 hours ago, NC Scroller said: I have a similar setup but I have mine mounted in a mini lathe. I use my mini lathe for the same thing. new2woodwrk 1 Quote
Wichman Posted September 13, 2020 Report Posted September 13, 2020 On 9/7/2020 at 4:44 PM, new2woodwrk said: Thanks Bill, I thought of this however, I have a Wen drill press and the chuck does not always stay seated, specially when using hole saw bits. I'm afraid if I put too much side pressure on the chuck I'll ruin it permanently. It's not the most robust of drill presses - it works for the most part for what I use it for though I have a drill press that had the same problem. Any side pressure and the chuck would just fall out. After many attempts to fix it (including a trip to a machine shop to have the morse taper checked) I finally used locktite, the lowest strength available at the time, I used a very light coat. Worked like a champ and the chuck stayed in place for 30+ yrs. I recently had the chuck fail and had to get a replacement (HF), The old chuck came out without a hassle (had to make a new drift key) but it popped out just fine. The new chuck installed without any hassle and has not come loose since the install. new2woodwrk 1 Quote
new2woodwrk Posted September 13, 2020 Author Report Posted September 13, 2020 On 9/11/2020 at 5:23 AM, NC Scroller said: If pieces like that are breaking while using a mop sander you might be pressing too hard. You really should just we touching the mop with the wood and not pushing. I also support the piece with my fingers or a small piece of scrap wood. What grit mop are you using? 320 seems like it would be the preferred grit? Quote
NC Scroller Posted September 13, 2020 Report Posted September 13, 2020 28 minutes ago, new2woodwrk said: What grit mop are you using? 320 seems like it would be the preferred grit? I have used the 180 and 220. I actually prefer the 180. I pre sand all my wood prior to scrolling. Usually no finer than 220. The only time I use finer paper is for pen turning. Since the wood is pre sanded I use the mop sander to "soften" or "take the roughness" and any fuzzies off the edges. new2woodwrk 1 Quote
Rolf Posted September 13, 2020 Report Posted September 13, 2020 (edited) I use a 240 grit mac mop on all of my fine sanding. including very delicate Christmas ornaments. The trick for me is I hold them on a flat piece of wood for support and the gently kiss the areas I want to sand. gently is the key word. by using a backer you are not stressing the work. I am not a fan of the Guinevere system as is, it should be variable speed. Edited September 13, 2020 by Rolf Tomanydogs, NC Scroller and new2woodwrk 2 1 Quote
Dennisfm56 Posted September 13, 2020 Report Posted September 13, 2020 If it's the "fuzzie's" you are sanding just use an acetylene torch and burn them off. You might want to hold the piece with a pair of pliers. new2woodwrk 1 Quote
new2woodwrk Posted September 13, 2020 Author Report Posted September 13, 2020 (edited) Thanks all, Really appreciate all the advice. I have a torch and have used it - not very good with it as I sometimes burn the wood and yes it's mostly the fuzzies I'm trying to get out. I have several mops and have used them on my drill press and Guinevere. I agree the Guinevere really needs to be variable speed. I've tried to set up a my hand drill to use, but that just adds another tool and more dust somewhere I don't need. I put 2 mops on the Guinevere and have been using as gentle a touch as I can. Sanding is by far my least favorite activity. Even when I build other items I dread the sanding portion It's probably also why I'll never get to Intarsia Edited September 13, 2020 by new2woodwrk Quote
