tomsteve Posted September 14, 2020 Report Posted September 14, 2020 spirals on portraits. flat on all else. no problems with control switching between them. if a problem with hand control, slowing the saw speed down might help FrankEV and new2woodwrk 1 1 Quote
Frank Pellow Posted September 21, 2020 Report Posted September 21, 2020 I use both, sometimes on the same project. I think of them exactly like using two different tools and, with this attitude firmly entrenched, I don't seem to have any problems switching. new2woodwrk and FrankEV 1 1 Quote
Woodrush Posted September 21, 2020 Report Posted September 21, 2020 On 9/8/2020 at 6:55 AM, FrankEV said: From what I have read in many post herein, some of you ONLY use straight blades and some ONLY use spiral blades. However, for those of you who use both in maybe a single project or maybe one or the other in separate projects, I wonder if you experience the same problems that I do. When you switch between blades do you find your hand control is messed up for a while until you have cut for a little while? I recognize eye/hand coordination is different based on the blade being used and relies a lot on mussle memory. As a result I find it dificult to follow the line with a straight blade after I had been using a spiral blade for a while. It also takes me a bit of time to get back into following the lines with a spiral blade after using a straight blade for a while. Just looking for any tips or advice to help hand control when switching between blade types. Thanks I try to do my spiral cuts first. I don't like spirals so I try to do most with straights. FrankEV and GusGustin 1 1 Quote
Woodrush Posted September 21, 2020 Report Posted September 21, 2020 On 9/8/2020 at 4:37 PM, GusGustin said: Okay .. that makes sense .. I love the Niqua's .. was going to try the NON-MG Pegas .. see if they are a little bit sturdier .. The non mg pegas are very sturdy. I use mostly pegas#2 supper skips and I get good mileage out of them. I find when the start to get dull is when I get the best control on tougher cuts. They do leave fuzzies but I get rid of them quick with a mini butane torch. FrankEV and GusGustin 1 1 Quote
GusGustin Posted September 24, 2020 Report Posted September 24, 2020 On 9/21/2020 at 11:46 AM, Woodrush said: The non mg pegas are very sturdy. I use mostly pegas#2 supper skips and I get good mileage out of them. I find when the start to get dull is when I get the best control on tougher cuts. They do leave fuzzies but I get rid of them quick with a mini butane torch. That's funny. I do the same. I can't wait for them to start to get dull . . . then my cuts are MUCH MORE IMPROVED. It's like ... 2a.m. with a piece of wood. Or - the blade just gets better and better after last call !!! hahahahaha Woodrush and kmmcrafts 1 1 Quote
