Eagle
RabidAlien
Very nice cutting.  I like eagles.
I have already done 4 different eagle plaques and I have about 15 more I plan to do over time.  I've got two projects getting ready to be cut and one is a very intricate Charlie Hand Eagle head pattern called The Guardian.  Will probably take me quite a few days to complete.
This one was fairly quick, although after I drilled all the pilot holes, I realized how MUCH of that pattern is "exterior" line.  It took me about as long to cut around the outside as it did to cut all the inside cuts...and the head is about the only place with a relatively straight line in the pattern!
51 minutes ago, Rockytime said:
Beautiful pattern and you've cut it and framed very nicely! How thick is the wood and how large is the pattern?
3/8 ply, I believe (dragged it out of the scrap bin).  The frame is 10x12, I believe, and made from the scrap pieces that come between layers of wood at Lowes, they toss 'em in a dumpster and let me rummage.  I like the knotty, beat-up, rustic look of that wood, but its pretty green (literally, its greenish in color) so each piece goes through several sanding cycles from 80grit up to 320grit to get it smoothed up a bit and take the surface layer of crud off.  Still ends up with a light greenish tint, but it takes a stain really well, and for the price, I can't complain.
I did that one. It's nor as bad as it looks. He has a way of making a pattern look like it has 400 holes when it only has 200. He told me he hates small tedious cuts
Yep, found that out myself!  I started looking at the interior cuts and realized there weren't all that many....20 or so?  The exterior, though....now, that part was FUN!  Great cornering practice.
It VERY NICE .. and all from scrap .. that's what I love to see and hear.  I love the pattern .. which one is it .. I would NOT mind trying that one for sure. FLAMING EAGLE .. and put it on a piece of backer with an HD or something ???? Oh yeah .. that would be a fun one !!!!
20 minutes ago, GusGustin said:
Is that pattern available ?
Yep, can't recall the name of it, but I found it scrolling through the Nature section of the Pattern Library.  Lemme rummage through there, see if I can find it again...
Edit:  Found it.  "Flaming Eagle" by Wild Bill, way back on page 14 of the "Animals" section.
Edited by RabidAlien
