Be_O_Be Posted September 17, 2020 Report Posted September 17, 2020 I use duck brand shelf paper on the wood & 77 on the pattern paper but with the cost & time of all three I'm willing to try something new. Is there a preferred brand of labels, better or worst, than other brands? Quote
Badgerboy Posted September 17, 2020 Report Posted September 17, 2020 On 9/14/2020 at 7:22 PM, dgman said: The nozzle clogs up because the glue builds up on the opening of the nozzle. It takes two seconds to wipe off the nozzle after each use. Also, I keep a couple of nozzles in a small jar of mineral spirits in case I need a fresh one. But since I have been wiping off the nozzle after each use, I haven’t needed to change it. I agree with dgman, I use 3M 45 only and brush a small amount of mineral spirits on the nozzle after every use, let it soak into the spray head for 5 seconds or so and replace the cap. I never had a spray problem or finishing the entire can. Speaking of 3M 45, anyone else had problems finding supply? I usually have no problem just running into my local big box and grabbing a few cans but recently I have had to search far and wide for just a few cans. Maybe more people are doing crafts being locked up at home. Quote
kmmcrafts Posted September 17, 2020 Report Posted September 17, 2020 (edited) 2 hours ago, Be_O_Be said: I use duck brand shelf paper on the wood & 77 on the pattern paper but with the cost & time of all three I'm willing to try something new. Is there a preferred brand of labels, better or worst, than other brands? Even with the labels I still use the Shelf liner... Though if your work isn't too fragile you can use a heat gun to loosen it off the wood directly.. but if the wood is not super smooth I've had cases of the labels not sticking real well.. the labels I use aren't super glue sticky like the spray glues are.. but they are way less messy in my opinion.. It's not real practical to use them if you just buy a few labels at a time from the store because they are pricey that way.. I buy them from the eBay link I posted earlier but he does sell smaller quantities and you can shop around to find a decent deal.. I came up with this by accident my first time.. as I use the labels to print m shipping labels and one day the printer had labels in it instead of regular paper.. been using them whenever possible ever since then, LOL.. I would buy a very small quantity first to see if you like them.. unless you have a use for them anyway.. Edited September 17, 2020 by kmmcrafts OzarkSawdust and Be_O_Be 1 1 Quote
rjweb Posted September 17, 2020 Report Posted September 17, 2020 I use 3m 45, works great not too sticky, get it at Home Depot, Lowe’s doesn’t carry it, RJ Quote
ben2008 Posted September 25, 2020 Report Posted September 25, 2020 (edited) On 9/14/2020 at 1:20 PM, dgman said: I’m always concerned about patterns loosening while I’m cutting. I use 3M 77 spray adhesive on the pattern, no tape underneath. As Brenda mentioned above, I spray mineral spirits on the cut pattern. It will lift right off. Then wipe off the mineral spirits and you’re good to go. If you don’t want to use mineral spirits, then you can heat the pattern with a heat gun or a hair dryer. The heat will loosen the adhesive and the used pattern will lift right off. I cover my wood with the sticky back shelf liner cut to size, then apply the pattern over it with the 3M 77 adhesive. Just make sure you wipe off any fine dust with a tack rag before applying shelf liner. Works for me. Edited September 25, 2020 by ben2008 Quote
BadBob Posted September 26, 2020 Report Posted September 26, 2020 17 hours ago, ben2008 said: Just make sure you wipe off any fine dust with a tack rag before applying shelf liner. Works for me. Do you have a recommendation for tack rags? The last ones I bought left a sticky residue and little bits of lint in the wood. I usually blow the dust off with compressed air or a blower. I like 3M Painters tape because there has to be a lot of dust to make it not stick. Quote
Gonzo Posted September 26, 2020 Report Posted September 26, 2020 I also use 3M77. Seems like the can lasts forever. I put the patten in an open box and spray the backside of pattern. When finished spraying, I take nozzle off and put it small jar. I do not recall ever having an issue with the pattern lifting. Quote
ike Posted September 26, 2020 Report Posted September 26, 2020 i USE SEVERAL TYPS OF SPRAY GLUE ALL ARE GOOD EXCEPT ELMERS THAT'S HORABLE.i HAVE BEEN SPRAYING DIRECTLY TO THE BOARD WITH A EVEN COAT SEMI LIGHT ADND IT HAS BEEN GOOD TO ME. i AM WORKING ON A LIGHT HOUSE WITH A LOT OR GRASS AND TREES.i HAVE ABOUT 8 HOURS ON IT NOW AND ARE A LITTLE OVER THE HALF WAY MARK WILL POST IT AND LET YOU KNOW . BUT BY SPRAYING THE WOOD AND THEN PLACEING THE PATTERN ON HAS BEEN VERY SUCESSFUL WILL TRLY THE ADDRESS LABLES SOON . pARDEN MY TYPING AND SPELLING i DON'T KNOW WHICH IS WORSE. ike Quote
ben2008 Posted September 26, 2020 Report Posted September 26, 2020 (edited) 9 hours ago, BadBob said: Do you have a recommendation for tack rags? The last ones I bought left a sticky residue and little bits of lint in the wood. I usually blow the dust off with compressed air or a blower. I like 3M Painters tape because there has to be a lot of dust to make it not stick. This is what I have been using. https://www.homedepot.com/p/Trimaco-SuperTuff-18-in-x-36-in-Tack-Cloth-6-Pack-10506/205754754 I also vacuum my wood if it has a lot of saw dust before I use the tack cloth. I never blow the saw dust off. It's just going to land somewhere else and maybe back on my project. I use this little mini vac attachments for my 5 gal shop vac. I also use it to vacuum off my scroll saw. Gets into the tight spaces. Fits 1 1/4 inch vacs. Works great. https://www.homedepot.com/p/Think-Crucial-32-mm-Mini-Micro-Tool-Attachment-Set-Fits-All-Vacuum-Cleaners-Including-Hoover-Eureka-Kenmore-and-Bissell-32MM-Mini-Micro-Tool/305847838?source=shoppingads&locale=en-US&mtc=Shopping-VF-F_D29A-G-D29A-29_16_FLOORCARE-Multi-NA-Feed-PLA-NA-NA-MinorAppl&cm_mmc=Shopping-VF-F_D29A-G-D29A-29_16_FLOORCARE-Multi-NA-Feed-PLA-NA-NA-MinorAppl-71700000032403373-58700003840533684-92700030729181853&gclid=Cj0KCQjwzbv7BRDIARIsAM-A6-1wmFRlMsWM_neZ-c-YKT_gByOAbEoYJKy3H3UWV7riA8fnU6h5WLgaAma4EALw_wcB&gclsrc=aw.ds Edited September 26, 2020 by ben2008 Quote
amazingkevin Posted September 30, 2020 Report Posted September 30, 2020 Best I ever used is 3m #45. It hate mineral spirits as a little removes the pattern depositional to with in a minute. Quote
