51 minutes ago, Rockytime said:
Great looking sign. Cut with straight blades or spiral? Cutting looks excellent!
Thanks Les. I used FDUR #1 except for the straight lines around the edges where I used FDUR #5's. I don't have much luck with spirals except for opening up a line I've already cut with a flat blade. I cut mostly thicker solid wood, this was 3/4". I imagine it might be easier to follow a line with a spiral on thinner plywood. It did make for a lot of tight twisting and turning on those small letters on the bottom. Probably took me 10-15 minutes per letter. :) I could never make good money at this. :)
Edited by Charlie E
10 hours ago, Tomanydogs said:
Wow Charlie I love everything about this piece. The wood the font the design. You did an excellent job of cutting. Outstanding.
Thank you so much! My wife's not easily impressed but she really likes this one. :) I'll brag a bit here. I made the shutters, the bench, the wind chimes, and the sign on the door too. ;)
Edited by Charlie E
Wow you should be proud that’s a great looking porch. It’s very handy to have a handyman around. You’re wife is a lucky lady.
