amazingkevin Posted September 16, 2020 Report Posted September 16, 2020 (edited) These were fancy chair and I had to salvage they but now stumbling offer them months not knowing what to use them for any items??? All are clear. Edited September 16, 2020 by amazingkevin Spelling new2woodwrk 1 Quote
new2woodwrk Posted September 17, 2020 Report Posted September 17, 2020 Are they colored or clear? I have a bunch of those as well, although mine are thinner - 1/4" I think. I'm hoping to make a dust control hood for my table saw. The rest I'm thinking of using as a zero insert for my miter saw, and a zero insert top for the scroll saw. If I have any left over, they will get used in frames some pieces yet to be identified amazingkevin 1 Quote
amazingkevin Posted September 17, 2020 Author Report Posted September 17, 2020 20 hours ago, new2woodwrk said: Are they colored or clear? I have a bunch of those as well, although mine are thinner - 1/4" I think. I'm hoping to make a dust control hood for my table saw. The rest I'm thinking of using as a zero insert for my miter saw, and a zero insert top for the scroll saw. If I have any left over, they will get used in frames some pieces yet to be identified These are 1/2" thick clear new2woodwrk 1 Quote
spirithorse Posted September 17, 2020 Report Posted September 17, 2020 Hi, Kevin, Lamps or night-lights like these come to mind https://sheilalandrydesigns.com/scroll-saw-pattern-category/lamps-nightlights/ or you could make an auxiliary top for a couple of your scrollsaws . If you make tops like that you could stick them to the existing table top and actually be using the upper portion of your scrollsaw blade that hadn't been worn out yet. With your painting skills, you could probably make some very, very nice sun catchers in any size you like or you could etch something into them and make some beautiful coasters. I have also seen etched name-plates on desks with just a name and title. You can etch with your rotary tool, sand blast (using a stencil), or you can buy creams at hobby stores especially for this (also using a stencil). God Bless! Spirithorse Bob amazingkevin 1 Quote
amazingkevin Posted September 18, 2020 Author Report Posted September 18, 2020 12 hours ago, spirithorse said: Hi, Kevin, Lamps or night-lights like these come to mind https://sheilalandrydesigns.com/scroll-saw-pattern-category/lamps-nightlights/ or you could make an auxiliary top for a couple of your scrollsaws . If you make tops like that you could stick them to the existing table top and actually be using the upper portion of your scrollsaw blade that hadn't been worn out yet. With your painting skills, you could probably make some very, very nice sun catchers in any size you like or you could etch something into them and make some beautiful coasters. I have also seen etched name-plates on desks with just a name and title. You can etch with your rotary tool, sand blast (using a stencil), or you can buy creams at hobby stores especially for this (also using a stencil). God Bless! Spirithorse Bob Hum. now that's interesting, cutting leaves a raw edge that needs to be heated to melt it clean, But etching or grinding might be a better way for me to go. i have an airbrush eraser i never used with lots of cutting abrasive. I just hate to throw things away that cost money i don't have, thanks for a great answer!!! and back or bottom lite is the ticket!!! Quote
JimErn Posted September 18, 2020 Report Posted September 18, 2020 You can finish the edges of cut lexan, or any plastic by putting some sheet sandpaper around a paperback book and curving the book while sanding the edge amazingkevin 1 Quote
amazingkevin Posted September 18, 2020 Author Report Posted September 18, 2020 1 hour ago, JimErn said: You can finish the edges of cut lexan, or any plastic by putting some sheet sandpaper around a paperback book and curving the book while sanding the edge Would a router be to rough and chip it,Thanks it;s 1/2" thick? Quote
Karl S Posted September 18, 2020 Report Posted September 18, 2020 2 hours ago, amazingkevin said: Would a router be to rough and chip it,Thanks it;s 1/2" thick? Not if you use a sharp bit and Light cuts Quote
JimErn Posted September 19, 2020 Report Posted September 19, 2020 18 hours ago, amazingkevin said: Would a router be to rough and chip it,Thanks it;s 1/2" thick? Never tried it, but I doubt I would, just thinking of how fast you could ruin the piece if something goes wrong the sand paper leaves a slightly frosted edge when viewed from the side amazingkevin 1 Quote
amazingkevin Posted September 19, 2020 Author Report Posted September 19, 2020 3 hours ago, JimErn said: Never tried it, but I doubt I would, just thinking of how fast you could ruin the piece if something goes wrong the sand paper leaves a slightly frosted edge when viewed from the side Thanks Jim I'm dieing to try cutting this stuff ,guess a skip tooth blade is best? Quote
JimErn Posted September 20, 2020 Report Posted September 20, 2020 On blade choice I'll leave it up to you, last time I did any was by hand with a hacksaw amazingkevin 1 Quote
amazingkevin Posted September 24, 2020 Author Report Posted September 24, 2020 On 9/20/2020 at 7:35 AM, JimErn said: On blade choice I'll leave it up to you, last time I did any was by hand with a hacksaw the Dewalt will hold a hacksaw blade, I'll try, thanks Quote
ike Posted September 24, 2020 Report Posted September 24, 2020 you might have to cut at a slower speed to keep it from melting togather behing the saw blade. IKE tomsteve 1 Quote
