2 hours ago, meflick said:
Nice work Frank. I haven’t seen that pattern before.
There are two patterns on one sheet from The Wodden Teddy Bear.  I liked this one the best of the two.  The other has the word LOVE as part of the stem also but in a script type font that you need to have the Rose horizontal in order to read it.
I  liked the simplicity of the single Rose, but without the addition of the color it just did not pop .  Even using a contrasting backer, as most projects do,  it was just tooooooo simple!
Thanks
10 hours ago, Rockytime said:
Nice work and well finished. Question: you refer to "solid core." Is that just three layers, one center layer with a veneer on each side? I'm just not familiar with the term
Yes, it is only three layers.  The center layer seems to be a dense wood celuloise (sp?) material. Cuts relatively clean if you are careful at  sharp points. Works well with both regular and spiral blades.
I believe the panels are intended for use with Laser cutting equipment.  I get them delivered to my home free in boxes of ten from Home Depot.  They are called Columbia Forest Products PureBond Plywood Project Panels and come in 5/32" thk or 1/4" thk and are 12" X19".  They can be gotten in various woods.  I typically use Maple and Walnut.  The walnut when stainded with a wallnut stain can be made very dark  for good contrast between the top and bottom layers of a project.  About $30/box or $3/panel, depending on the thickness and wood type.
IMHO it cuts nicer/cleaner and finishes better than BB Ply.
12 hours ago, spirithorse said:
A little hard to see the rose detail in the pic but, the project looks great!
Thanks for sharing and God Bless! Spirithorse
I use natural window light when I shoot the pics of my projects on wall in my sunroom.  All the pics come out a little on the dark side but if I use flash there is toooo much harsh light bounce back.  I need to get a better photo light source. Next I'll be probably have to build a photo studio to take pics of the projects.🤔
21 hours ago, FrankEV said:
This is a Wooden Teddy Bear pattern cut out of 1/4" solid core ply using a Pegas #1 MGT and a #1 Pegas spiral blade for the leaves.  The Rose is painted with craft acylic paints.  The backer is an  8x10 piece of 1/8" thk BB Ply stained with a clear stain.  After the painted rose was glued to the backer the panel was finished with multiple coats of clear gloss lacquar.   The panel is loose fit into a store bought frame and uses the cardboard backer with table stand that comes with the frame to hold the panel into the frame.  It can, therefore, be a wall hanging or table displayed.
This was a quick "fun cut" taking less than 2 hours.  Painting and finishing was much more time consuming that the scroll work.
Well with the painting, it really stands our well. Nice job and two hours well spent
Dick
heppnerguy
