Foxfold Posted September 20, 2020 Report Posted September 20, 2020 (edited) Now some of you may remember my run in with CA glue, so it's not my favourite and to be honest I'm a little scared of the stuff. However, at times it is very useful. I use the tiny bottles pictured below but find that the teeny nozzle gets clogged up with dry glue quite badly and I'm never going to take the top off completely ever again so I'm asking to see if anyone knows how to prevent this. I've tried poking it with a saw blade but even that doesn't seem to work very well plus I find I have to put the bottle in a small vice in order to hold it still while I poke. Edited September 20, 2020 by Foxfold OCtoolguy 1 Quote
Norm Fengstad Posted September 20, 2020 Report Posted September 20, 2020 I often use ca glue to stack cut, I over size the boards a bit then putting a drop on each corners and on the edge clamp for a few minutes and it is good to go. It is easy to separate with a slim drywall scraper. amazingkevin and OCtoolguy 2 Quote
Bill WIlson Posted September 20, 2020 Report Posted September 20, 2020 I use this type of CA glue. It's more expensive, but the cap seems to do a good job of preventing the tip from clogging. I've never had an issue with that. Never had a bottle dry out on me either. OCtoolguy, Be_O_Be and Foxfold 2 1 Quote
Rockytime Posted September 20, 2020 Report Posted September 20, 2020 I've used ca for years. Before replacing the cap I give the bottle bottom a very sharp rapp on the bench to clear the tip, then replace the cap. OCtoolguy, munzieb, Foxfold and 3 others 3 3 Quote
dgman Posted September 20, 2020 Report Posted September 20, 2020 6 minutes ago, Rockytime said: I've used ca for years. Before replacing the cap I give the bottle bottom a very sharp rapp on the bench to clear the tip, then replace the cap. Also, never use the tip to spread the glue and never let the tip touch the work piece. Foxfold and OCtoolguy 1 1 Quote
Foxfold Posted September 20, 2020 Author Report Posted September 20, 2020 Thank you all, I'll take all your comments on board. As I say, I don't use it often, 2yrs on and I still have the scars from this stuff. OCtoolguy 1 Quote
jollyred Posted September 20, 2020 Report Posted September 20, 2020 When my bottle of ca has the end closed with dried glue, I take a knife and pop off the plug. Cut from the bottom of the plug on the side of the nozzle and cut towards the end of the nozzle. Might have to take a couple of cuts, but it will pop out the plug in the nozzle. Tom OCtoolguy and amazingkevin 2 Quote
Foxfold Posted September 20, 2020 Author Report Posted September 20, 2020 31 minutes ago, jollyred said: When my bottle of ca has the end closed with dried glue, I take a knife and pop off the plug. Cut from the bottom of the plug on the side of the nozzle and cut towards the end of the nozzle. Might have to take a couple of cuts, but it will pop out the plug in the nozzle. Tom Thanks Tom. However, I'll not try cutting if you don't mind, knowing my luck I'll end up on crutches again . Gene Howe, OCtoolguy and amazingkevin 1 2 Quote
OCtoolguy Posted September 20, 2020 Report Posted September 20, 2020 3 hours ago, Foxfold said: Thanks Tom. However, I'll not try cutting if you don't mind, knowing my luck I'll end up on crutches again . Brenda, you might want to take up a new hobby. Maybe something with "PlayDough" comes to mind. LOL> amazingkevin, Gene Howe and Foxfold 1 2 Quote
merlin Posted September 20, 2020 Report Posted September 20, 2020 Brenda as mentioned tap the bottom on the bench, never use the tip to spread the glue and my favorite (over years of glue clogging of any sort) Always stand the bottle/tube upright when not in use.... I even made a holder to sit the glue tubes in..Sorry no pics.... OCtoolguy and Foxfold 1 1 Quote
danny Posted September 20, 2020 Report Posted September 20, 2020 Not sure what its called like ca glue etc. but I bought lil bottle last year and like Wow! Never had a lick of trouble with the bottle. Its name is 401 glue. FB runs adds sometimes. The Videos for its use is another Wow! Stronger than Anything I think......................Danny :+} OCtoolguy, Foxfold and amazingkevin 2 1 Quote
Foxfold Posted September 21, 2020 Author Report Posted September 21, 2020 10 hours ago, danny said: Its name is 401 glue. Thanks Danny. I went looking and also found their Perfect Pen which is absolutely perfect for me. No drips, no clogging and comes out of a very fine point. OCtoolguy and amazingkevin 2 Quote
Rolf Posted September 21, 2020 Report Posted September 21, 2020 (edited) I use a fair amount of it , thin, medium and thick. It is a must have for wood turners. It is great as a pen finish and I recently finished a shift knob for my car. I do threat it with respect, not only the glue aspect but also the fumes are not healthy. When I am done with my CA glue I just squeeze the bottle while upright into a paper towel to make sure there is no residue in the nozzle. I also have a pin vise with a tiny drill bit to open it if need be. Edited September 22, 2020 by Rolf OCtoolguy, danny, John B and 2 others 5 Quote
Foxfold Posted September 21, 2020 Author Report Posted September 21, 2020 1 hour ago, Rolf said: I do threat it with respect Yep, me too. I've been on the 'other' end of this glue and it's not pleasant. John B, amazingkevin and OCtoolguy 1 2 Quote
Foxfold Posted September 23, 2020 Author Report Posted September 23, 2020 Got this one, it seems to tick all my boxes. amazingkevin and OCtoolguy 1 1 Quote
amazingkevin Posted September 23, 2020 Report Posted September 23, 2020 On 9/20/2020 at 10:45 AM, Bill WIlson said: I use this type of CA glue. It's more expensive, but the cap seems to do a good job of preventing the tip from clogging. I've never had an issue with that. Never had a bottle dry out on me either. Cut the bottle open and you will find the teeny tiny bottle Foxfold has inside,even smaller. OCtoolguy and Foxfold 1 1 Quote
Ctutor Posted September 23, 2020 Report Posted September 23, 2020 I always have a bottle of acetone around when using CA. It is a quick solvent and will undo skin stick togethers if necessary OCtoolguy 1 Quote
ike Posted September 23, 2020 Report Posted September 23, 2020 the only place that i use this glue is when I tied fishing fly's , now that i am older I buy all my flyes. I put a drop on all the knots , It makes it harder for a fish to tear up a fly. besides that my wife used to bitch about all the feathers. IKE OCtoolguy 1 Quote
Foxfold Posted September 23, 2020 Author Report Posted September 23, 2020 1 hour ago, Ctutor said: I always have a bottle of acetone around when using CA. It is a quick solvent and will undo skin stick togethers if necessary This was the result of the glue landing on cotton sock after knocking a small bottle over . The reaction was heat and smoke that welded the sock to my foot. Not sure that, even if I had it, acetone would have made a difference . OCtoolguy 1 Quote
ben2008 Posted September 23, 2020 Report Posted September 23, 2020 This what I use. No problem with clogging or drying out. https://www.amazon.com/Professional-Grade-Cyanoacrylate-Glue-Masters/dp/B00WHEM0UA/ref=sxts_sxwds-bia-wc-p13n1_0?cv_ct_cx=glue&dchild=1&keywords=glue&pd_rd_i=B00WHEM0UA&pd_rd_r=9f6f5d81-37a0-466e-8528-557106798e65&pd_rd_w=sIpm1&pd_rd_wg=AGcIx&pf_rd_p=224b59c9-c98f-46fd-96d6-8e952866d6a3&pf_rd_r=Q7G5560QH7S206FBT5MJ&psc=1&qid=1600877135&sr=1-1-a14f3e51-9e3d-4cb5-bc68-d89d95c82244 Foxfold 1 Quote
