indiana_jones Posted April 7, 2009 Report Posted April 7, 2009 hi everyone, i hope you are all doing fine. i have a question, first of all i have a floor , full size drill press, and for some time now i have been wanting something smaller to drill the many holes , we need for scroll saw work. i know they make bench top drill press but they all have the same huge motor, and top. so do they make a hobby size drill press? i know they make a drill press that you can mount a drill in, but before i buy that i want to make sure there is not something better. thanks Quote
blame Posted April 7, 2009 Report Posted April 7, 2009 what about a dremel with the plunge router base? i read somewhere where somebody was doing that i my self just use my 18 volt cordless drill http://www.totaltoolandhome.com/product.sc;jsessionid=C5BBD1151F7FFF427B81F2A66ABFA9F9.qscstrfrnt01?productId=243 Quote
Travis Posted April 7, 2009 Report Posted April 7, 2009 I'd recommend the Dremel plunge router as well. Problem with benchtop drill presses is the throat capacity is a bit short. With the Dremel plunge router, you won't have to worry about that at all. Plus you can use your Dremel for a multitude of other purposes, which is always nice. But I got away for the longest time with a cheap $16 corded hand drill. Works just fine, assuming you don't need exactly square holes, which was the majority of my projects (I tend to do portrait style cuttings). Hope this helps! Quote
joleet Posted April 7, 2009 Report Posted April 7, 2009 Travis and blame is right on with thier suggestion. I have a radial arm Craftsman drill press which is terrific for very large items but wanted something more portable so I took the suggestion of a member and bought a plunge router for my Dremel and havent gone back to the drill press since. The bests thing is the portability of it, I can take it anywhere, closer to good lighting, tall bench, sit down bench, etc.. The only thing that I have found is that if you need to change bit sizes quite often, it is a little more of a pain to change them, so I try to plan my drilling so not to change as much. Ron T. Quote
