Hello. I am doing some 3D ornaments and birdhouses. I've used walnut, red oak, cherry, maple, and butternut so far and they seal and finish fine with both shellac and lacquer. My issue is; I cannot get basswood to do anything but soak up the finish, no sheen, no shine, nothing. Does anyone have success finishing basswood?
Thanks, Steve
Thanks for the reply. I actually have used four coats of blond shellac, dipped and dried. Multiple sprayed coats of lacquer, same result. Haven't tried poly yet, so it's next.
Edited by SteveS
Trees absorb nutrients and water to grow. When dead and called wood the structures of different wood species will still do the same thing.  People painting houses or painting/ staining projects have had this problem for centuries. Technology developed 'Wood Sealers'. Searching for wood sealer will give you a variety of products. Between commercial products, forum boards and home made recipes online, coating your project with one of these will stop the absorption. RJF
Edited by teachnlearn
  • 1 month later...
Maybe mix wood glue with water until appropriately thinned and paint the project with that first?  If the wood is just sponging up sealer it needs to be ‘plugged’ first.  The glue should still take a stain, just not as well as the wood would have.
