Popular Post munzieb Posted October 4, 2020 Popular Post Report Posted October 4, 2020 Whew! Finally done. I took almost a month to do this Art Deco Weave Pattern Box. I used 1/4" Padauk and there are 200 holes per panel. I used a #2 skip tooth blade. Cutting Padauk definitely requires using a mask. It has a peppery smell but the fine dust can affect you. Finish is gloss lacquer. I had thought about doing another lamp but the pattern was going in the wrong direction. I like the feet. I mounted small blocks on the edges. I had left overs from trimming the panels and used my belt sander and set the fence of the disk sander to 45 degrees. I used the miter on the fence to hold it straight and ground down to the 45. Since it's only 1/4", it went very fast. Trimmed the pattern on the scroll saw and sanded a radius on the edges of each piece. I cut off the reverse excess trim on the long piece and ground off another 45 and repeated 4 times for for the left and 4 times for the right/opposite side. Laid down blue tape and place the opposing pieces down with the matching 45's, glued and squeezed together. I set the box on a flat surface. My 1/4" glass plate is perfect for that. I CA glued each piece to the corners and made sure they were flat. It definitely gives it a more finished furniture look. Wilson142, amazingkevin, New Guy and 18 others 16 5 Quote
Badgerboy Posted October 4, 2020 Report Posted October 4, 2020 Amazing, you’re endless with these awesome creations of lovely art! munzieb 1 Quote
Be_O_Be Posted October 4, 2020 Report Posted October 4, 2020 That is one great looking piece! Were you able to stack cut the side panels? munzieb 1 Quote
munzieb Posted October 4, 2020 Author Report Posted October 4, 2020 15 minutes ago, Be_O_Be said: That is one great looking piece! Were you able to stack cut the side panels? Initially I had thought about stack cutting but the cuts were so thin, I was concerned that one small slip would would have ruined several pieces. I may have considered if it was a larger (size) pattern. That's why it took so long to cut. Be_O_Be and danny 1 1 Quote
spirithorse Posted October 4, 2020 Report Posted October 4, 2020 Fantastic work and a beautiful project! Thanks for sharing and God Bless! Spirithorse danny and munzieb 2 Quote
Rockytime Posted October 5, 2020 Report Posted October 5, 2020 Fantastic looking piece! It surely was worth the effort. munzieb 1 Quote
RabidAlien Posted October 5, 2020 Report Posted October 5, 2020 This. Is. AWESOME!!!! Where'd you find the pattern, if I may ask? munzieb 1 Quote
wombatie Posted October 5, 2020 Report Posted October 5, 2020 Oh my that is the most impressive piece of art that I have ever seen. That would get first prize in any woodworking competition. Excellent work Bernd. Marg munzieb and danny 2 Quote
Foxfold Posted October 5, 2020 Report Posted October 5, 2020 Oh WOW !! That is an Amazing piece. !! munzieb 1 Quote
barb.j.enders Posted October 5, 2020 Report Posted October 5, 2020 Wowzzer!!! That is amazing work. munzieb 1 Quote
amazingkevin Posted October 5, 2020 Report Posted October 5, 2020 I,m sure you scoured the web to find this gem!!! Mighty impressive piece done to perfection. It will be hard to part with this one but the kind of money it will bring will change your mind!!! munzieb 1 Quote
Dave Monk Posted October 6, 2020 Report Posted October 6, 2020 Wow! That is a beauty! munzieb 1 Quote
Denny Knappen Posted October 6, 2020 Report Posted October 6, 2020 A work of art. Priceless. munzieb 1 Quote
