wombatie Posted April 28, 2011 Report Posted April 28, 2011 I know some of you already use this little tip but I thought some of the new members may not know of it so I took some photos to explain. To use more of the blade cut yourself a board to fit the surface of your scroll saw, I used melamine and put a hole where the blade comes though, this allows you to lift your work to get more out of your blades and not to waste unused blades space. The first photo shows the under side, where I glued a piece of non slip material and 3 little legs that sit over the side of the scroll saw to avoid any slipping while cutting. The second is of the board sitting on top of the scroll saw and the third is obviously the scroll saw. Marg Quote
PawPawRay Posted April 29, 2011 Report Posted April 29, 2011 Had not thought of attaching it that way. Great idea. I've been using double back tape. Like your way better, easier to put on and take off. Quote
Radh1 Posted May 1, 2011 Report Posted May 1, 2011 I really like this Idea,Thanks for sharing.. Quote
WolfmoonCT Posted May 1, 2011 Report Posted May 1, 2011 I like the idea, but it will defeat the reverse tooth blades I'm using. Quote
