Frank Pellow Posted October 9, 2020 Report Posted October 9, 2020 (edited) This is made up of 6 layers of 3mm thick Baltic Birch Plywood. Layers 2, 4, and 6 are stained with Saman water-based stain. the layer 2 colour is Canadian Maple the layer 4 colour is Walnut the layer 6 colour is Dark Walnut All the sawing was done with Flying Dutchman #1 Ultra Reverse blades and it took about 3 hours to cut. The Rosseter-Pellow frame is made of 1/4 sawn White Oak and stained with Saman Black water-based stain. After staining, the frame was sanded to give it a distressed appearance. Everything is finished with 3 coats of semi-gloss clear rattle-can spray stuff. Here is a photo of the layers before staining and assembly: Here it is after staining and assembly: And, here it is after framing: Unfortunately, the layering is hard to see in a two dimensional photo, but it is quite effective. Edited October 9, 2020 by Frank Pellow frankorona, jollyred, Be_O_Be and 5 others 8 Quote
trackman Posted October 9, 2020 Report Posted October 9, 2020 I really like the frame you made. Did you cut the curve inside corners after you put it together? Quote
Frank Pellow Posted October 9, 2020 Author Report Posted October 9, 2020 2 minutes ago, trackman said: I really like the frame you made. Did you cut the curve inside corners after you put it together? Thanks. Yes, I cut the bevels using my router table after I assembled the frame. If you are interested in making such frames yourself, contact me via email at fpellow@sympatico.ca and I will send you detailed step by step instructions. Quote
barb.j.enders Posted October 9, 2020 Report Posted October 9, 2020 27 minutes ago, Frank Pellow said: Thanks. Yes, I cut the bevels using my router table after I assembled the frame. If you are interested in making such frames yourself, contact me via email at fpellow@sympatico.ca and I will send you detailed step by step instructions. Frank, i have sent you an email as well. Hope you dont get overwhelmed Quote
wombatie Posted October 9, 2020 Report Posted October 9, 2020 Terrific work Frank, well done. Marg Frank Pellow 1 Quote
heppnerguy Posted October 9, 2020 Report Posted October 9, 2020 The frame was a great addition to your well cut pattern. I need to take time to frame more of what I make, as it is easy to see how much it adds to a project. Dick heppnerguy Frank Pellow 1 Quote
kywoodmaster Posted October 9, 2020 Report Posted October 9, 2020 Love it. That old Chevy brings back a lot of memories. Frank Pellow 1 Quote
alexfox Posted October 9, 2020 Report Posted October 9, 2020 10 hours ago, Frank Pellow said: Unfortunately, the layering is hard to see in a two dimensional photo, but it is quite effective. Nice cutting! Agree, that is why I make short video to show my customers how finished project will look like. my YouTube channel Be_O_Be and Frank Pellow 1 1 Quote
Frank Pellow Posted October 9, 2020 Author Report Posted October 9, 2020 45 minutes ago, alexfox said: Nice cutting! Agree, that is why I make short video to show my customers how finished project will look like. my YouTube channel Alex, the video helps somewhat and I did look at it before purchasing the pattern, but it is still two dimensional and I did not see the full effect until making the piece. As you can see, I used some of the same stains on both this piece and the fretwork Farm Truck piece. Also, the frames that I made for them are similar. I'm planning to hang them as a pair on a wall in my office. Quote
spirithorse Posted October 9, 2020 Report Posted October 9, 2020 Well done, Frank! I did not realize how many layers there were in this version when I looked at your other post with the poll. Thanks for sharing and God Bless! Spirithorse Frank Pellow 1 Quote
Frank Pellow Posted October 10, 2020 Author Report Posted October 10, 2020 On 10/8/2020 at 10:25 PM, barb.j.enders said: Frank, i have sent you an email as well. Hope you dont get overwhelmed Barb, I sent you and three others the instructions. My grandfather taught me the basic design of the Rosseter-Pellow frames that I use and I am happy to be able to pass his tips on to others. Quote
barb.j.enders Posted October 10, 2020 Report Posted October 10, 2020 2 hours ago, Frank Pellow said: Barb, I sent you and three others the instructions. My grandfather taught me the basic design of the Rosseter-Pellow frames that I use and I am happy to be able to pass his tips on to others. Thank you Frank. I received the email. I have read the directions. Hope to get a chance soon to try it out. I don't have all the tools you use, so will have to do some improvising. Quote
Frank Pellow Posted October 10, 2020 Author Report Posted October 10, 2020 1 hour ago, barb.j.enders said: Thank you Frank. I received the email. I have read the directions. Hope to get a chance soon to try it out. I don't have all the tools you use, so will have to do some improvising. Barb, by no means ae all the tools that I use in the examples document necessary. I've made this type of frame using hand tools only. Quote
GusGustin Posted October 10, 2020 Report Posted October 10, 2020 Very NICE work !!! Frank Pellow 1 Quote
barb.j.enders Posted October 11, 2020 Report Posted October 11, 2020 10 hours ago, Frank Pellow said: Barb, by no means ae all the tools that I use in the examples document necessary. I've made this type of frame using hand tools only. So how does one make a rabbet in the wood without a router or table saw? Quote
Frank Pellow Posted October 11, 2020 Author Report Posted October 11, 2020 (edited) 2 hours ago, barb.j.enders said: So how does one make a rabbet in the wood without a router or table saw? Back when my grandfather taught me, we used a backsaw with a rip blade (carefully): Another way is to glue two pieces of wood together. Edited October 11, 2020 by Frank Pellow barb.j.enders 1 Quote
