8 hours ago, rjweb said:
I am in the process of making this for my daughter, what size hole did you use for the numbers, Thx RJ
If you're drilling, just use one or two sizes up from 1/4".  I just cut the holes with the scroll saw like all of the other negative spaces I removed.  Worked out fine for me.
On 10/15/2020 at 11:35 AM, RabidAlien said:
Cut this Steve Good pattern for my wife to take to the office.  Apparently, mid-October is way too soon to bring Christmas decorations in.   LOL  1/4" bbply, Pegas #1MG blades.  Backer/posts stained Minwax Provincial, pattern/numbers are Minwax Natural.  I ended up scrolling all of the holes, even the peg holes, cutting ON the line instead of just skirting inside it.  My drill bits could use some sharpening or replacing, the 1/4 for some reason tends to chew up the backside of the project, unless its heavy lumber.  Worked out just fine that way, the 1/4" oak dowel was a snug fit with no need for any extra sanding.
A really cute piece..  should be one that others are going to come to you for
Dick
heppnerguy
