Fish Posted October 17, 2020 Report Posted October 17, 2020 Anyone else ever use your hammer to flatten the ends of a spiral blade a little more so it was easier to get in the clamps? I never thought of it before. It works fine so far and hasn't weakened the metal. Time will tell. Quote
Foxfold Posted October 17, 2020 Report Posted October 17, 2020 Yep, guilty as charged. I find it much easier to 'hit' it than to try and get it untwisted as my hands are not good. !! Never had a problem doing this. Quote
Denny Knappen Posted October 17, 2020 Report Posted October 17, 2020 Here I am a Pegas dealer, but Flying Dutchman sells flat end spiral blades. amazingkevin 1 Quote
Fish Posted October 18, 2020 Author Report Posted October 18, 2020 I’ll look in to those next time I need blades. Thanks. Quote
Bill WIlson Posted October 18, 2020 Report Posted October 18, 2020 Flying Dutchman does offer flat end blades, but not in their smallest sizes. I generally use the 2/0 spiral, sometimes a 3/0 and they aren't available in the flat end, so I end up untwisting them. I use 2 pair of pliers. I grip the end of the blade, about an inch or so from the end with one pair and use it to hold it like a vise. Then I use the other pair to untwist the blade. The important thing is to get both ends in approximately the same plane, when flattening/untwisting. Makes getting them in the clamps easier. I tried the hammer it flat method when I first started using spirals. I didn't have much luck with it. Many of the blades broke shortly after applying tension. I think I had a bad batch of blades, but I've developed my technique for straightening them with the pliers and it works for me, so I haven't gone back to hammering them. Foxfold and Fish 2 Quote
Iguanadon Posted October 18, 2020 Report Posted October 18, 2020 I use a hammer on spiral blades to crush them into tiny balls, then burn them, then bury them. DEEP. They are pure evil and I don't want them coming back to life. scrollerpete, OzarkSawdust, Frank Pellow and 6 others 8 1 Quote
Wilson142 Posted October 18, 2020 Report Posted October 18, 2020 26 minutes ago, Iguanadon said: I use a hammer on spiral blades to crush them into tiny balls, then burn them, then bury them. DEEP. They are pure evil and I don't want them coming back to life. A clear case of operator error. lol Iguanadon, innar20 and WayneMahler 3 Quote
Norm Fengstad Posted October 18, 2020 Report Posted October 18, 2020 hadn't thought about hammering the spirals flat, maybe I will give it a try. I have been squishing them flat when installing using the screw blade holder to do the job. Quote
amazingkevin Posted October 18, 2020 Report Posted October 18, 2020 That's what I liked so much about the old Delta spring loaded blade holders .They loved spirals and would grip and hold the first time! Quote
Frank Pellow Posted October 18, 2020 Report Posted October 18, 2020 4 hours ago, Bill WIlson said: Flying Dutchman does offer flat end blades, but not in their smallest sizes. I generally use the 2/0 spiral, sometimes a 3/0 and they aren't available in the flat end, so I end up untwisting them. I use 2 pair of pliers. I grip the end of the blade, about an inch or so from the end with one pair and use it to hold it like a vise. Then I use the other pair to untwist the blade. The important thing is to get both ends in approximately the same plane, when flattening/untwisting. Makes getting them in the clamps easier. I tried the hammer it flat method when I first started using spirals. I didn't have much luck with it. Many of the blades broke shortly after applying tension. I think I had a bad batch of blades, but I've developed my technique for straightening them with the pliers and it works for me, so I haven't gone back to hammering them. That's a good tip Bill and I will ty it. I, too, mostly use 2/0 spiral and, since they are so fragile, don't take well to hammering. Quote
OzarkSawdust Posted October 18, 2020 Report Posted October 18, 2020 6 hours ago, Iguanadon said: I use a hammer on spiral blades to crush them into tiny balls, then burn them, then bury them. DEEP. They are pure evil and I don't want them coming back to life. I agree with Iggy!! Quote
stoney Posted October 19, 2020 Report Posted October 19, 2020 The issue I have found with Flying Dutchman flat end spirals is the ends are not on the same plane and have to be tweaked. They are not ready to use right out of the packaging. Quote
dvdneal Posted October 19, 2020 Report Posted October 19, 2020 I just used some the other day. They don't work as well as a regular blade, but I had no problem getting my dewalt to clamp them down. I believe I was using a 2/0, but I could have been under the influence. I was using a spiral blade afterall. Quote
