I like the way that you did this.
I've been asked to create a wide but narrow stained glass piece to go into the high-up window in a friend's bathroom and I am thinking that what you did here, only with a turquoise glass backing, might be more appealing than the traditional stained glass that I was planning to make.
If I decide to proceed with this, where can I obtain that patterns that you used?
That sounds like a nice undertaking.
These Underwater Sea Creature patterns are from the Scroller Website. (https://www.scrolleronline.com) There are a few different subject patterns also, like butterflys and frogs.  They come in a 3 pack but a slight discount if you buy the 6 pack.  The patterns are nominal 8" diameter and that is why I had to stagger them to fit on a 48" backer.
On 10/28/2020 at 11:16 AM, FrankEV said:
In a thread under Q&A I previously asked the question about how "Wall Art" is normally displayed, as there are no suggestions for backers or frames.  Based on some of the answers I received this is what I did.
My lady, Robin, specifically found these six Underwater Sea Creature patterns from the Scroller Website and she asked me to cut them for her.
They are cut from 1/4"BB Ply and left unstained. I mostly used Pegas #0 spiral blades to cut the patterns.  As they are "Wall Art", I decided I would need to create my own "wall", as I did not think they would look good hanging by themselves on our nearly white walls.
The backer is 12" x 48" long piece of 1/4" Luan plywood painted with 3 coats of custom colored wall paint. The base color was Valspar Blue Turquoise that I streaked the wet third coat with Valspar Turquoise Tint to add some light colored high lights.   I purchased sample jars of the paint from the Lowes paint department.  After mounting the cuts to the backer I finished the panel with multiple coats of spray Lacquer.
I made the custom size frame from cut down pre-primed brick mold, also from Lowes, which I then finished painted with rattle can spray high gloss white enamel.
I think this project came out fairly well and we now have our own Wall Art Aquarium and Robin is happy...that is all that matters!
Looks great. Excellent
