stoney Posted October 29, 2020 Report Posted October 29, 2020 I guess I am doing something wrong as I can't retrieve a thread I posted about changes I made to my Hegner Multi-Max 22v to make it more user friendly. I thought it might serve new Hegner owners that haven't seen it to take a look. OCtoolguy 1 Quote
kmmcrafts Posted October 29, 2020 Report Posted October 29, 2020 1 hour ago, stoney said: I guess I am doing something wrong as I can't retrieve a thread I posted about changes I made to my Hegner Multi-Max 22v to make it more user friendly. I thought it might serve new Hegner owners that haven't seen it to take a look. Are you talking about this topic? OCtoolguy 1 Quote
stoney Posted October 29, 2020 Author Report Posted October 29, 2020 Yes Kevin that is the one I was searching for, Thank you. OCtoolguy 1 Quote
OCtoolguy Posted October 29, 2020 Report Posted October 29, 2020 Al, I'd make a note of this post for future gens to view it. All good info. stoney 1 Quote
Scrappile Posted November 21, 2020 Report Posted November 21, 2020 @stoney, just wanted to let you know,,, I did "the mod" on my Hegner a little over a week ago. It turned out to be very simple, as you said... the longest part being taping the hole. I was going real slow and careful doing that,,,, in a little ways back, in a little more and back out... Got the spring at an Ace Hardware. It was a little weak, held the arm up, but when I lowered the arm there was hardly any resistance and I didn't like the feel.... My saw also seemed to have more vibration than before the mod... so I made the spring a little shorter and it really helped. Not sure if the spring caused the vibration, I had to move the saw to work on it and I have to get it back in just the right spot or it will vibrate more. Anyway, I got it done and I glad I did it... helps to have the arm go up higher... I need to find a little orange paint now... stoney, Jim Finn and OCtoolguy 3 Quote
stoney Posted November 21, 2020 Author Report Posted November 21, 2020 I am glad to hear you like the modification Paul. I didn't experience the vibration issue you mentioned. I read somewhere that Kubota tractors paint is a good match. OCtoolguy and Scrappile 1 1 Quote
Scrappile Posted November 21, 2020 Report Posted November 21, 2020 3 hours ago, stoney said: I am glad to hear you like the modification Paul. I didn't experience the vibration issue you mentioned. I read somewhere that Kubota tractors paint is a good match. Ha, I'm too cheap to buy a whole can of paint for that little touch up... Maybe I will just put a smiley face sticker over it or something.... Jim Finn, OCtoolguy and stoney 1 2 Quote
Scrappile Posted December 6, 2020 Report Posted December 6, 2020 Just a word to the wise.... If you do this mod,,,, remember not to put you magnifying light quite as close to your work as you use to...... if the blade brakes, the arm will pop up it will be popping higher than it did before and BAM.....! Almost sent the light right into my nose!!! Cracked the protective piece over the light bulb....! be right back,,, got to take a shower and change my pants... OCtoolguy and stoney 2 Quote
stoney Posted December 7, 2020 Author Report Posted December 7, 2020 (edited) On 12/6/2020 at 2:25 PM, Scrappile said: Just a word to the wise.... If you do this mod,,,, remember not to put you magnifying light quite as close to your work as you use to...... if the blade brakes, the arm will pop up it will be popping higher than it did before and BAM.....! Almost sent the light right into my nose!!! Cracked the protective piece over the light bulb....! be right back,,, got to take a shower and change my pants... Just wondering Paul did you change the spring when you moved the stop? I installed a much lighter spring as it only has to be strong enough to hold the arm in the raised position. Yea I probably should have noted the arm does raise substantially more, like several inches. Other than scaring the daylights out of ya, how do you like the extra room the mod created? Edit: I just reread your first post and answered my own questions! Yea if you use a spring with to much tension the arm behaves like a catapult!! LOL Edited December 7, 2020 by stoney OCtoolguy 1 Quote
Scrappile Posted December 7, 2020 Report Posted December 7, 2020 I had a lighter spring, but it was too light... for me. The arm would stay up, but was too easy to pull down,,, just didn't feel right to me... so I put on a little heavier one. I like having the arm go higher... OCtoolguy and stoney 2 Quote
