puzzleman Posted November 13, 2020 Report Posted November 13, 2020 Attached are pics of my recent dust collection scheme. I used Rockler's Dust Right connections plus a Shop Vac straight tube section and floor attachment under the table. I hook everything up to a mobile Seyco dust collector. No more dust on the floor and the top tube picks up all the dust on top of the table. new2woodwrk, OCtoolguy, kmmcrafts and 2 others 4 1 Quote
kmmcrafts Posted November 13, 2020 Report Posted November 13, 2020 Very nice set up.. I keep watching these dust collection topics.. someday when I'm less busy and can get out and shop around to pick up some of the hose fittings etc.. I'm building and experimenting with different systems.. I'm not 100% satisfied with the seyco dust collector setup that I currently have.. works great for the stuff below the table... but the dust from the top gets knocked off the top and still ands in my lap and around.. I'll first try hooking a T or Y into my current system and see if it has enough to pull from both to get more of the dust from the top side.. It may work but I sorta have doubts.. Thanks for sharing your setup OCtoolguy and Be_O_Be 2 Quote
puzzleman Posted November 13, 2020 Author Report Posted November 13, 2020 22 minutes ago, kmmcrafts said: Very nice set up.. I keep watching these dust collection topics.. someday when I'm less busy and can get out and shop around to pick up some of the hose fittings etc.. I'm building and experimenting with different systems.. I'm not 100% satisfied with the seyco dust collector setup that I currently have.. works great for the stuff below the table... but the dust from the top gets knocked off the top and still ands in my lap and around.. I'll first try hooking a T or Y into my current system and see if it has enough to pull from both to get more of the dust from the top side.. It may work but I sorta have doubts.. Thanks for sharing your setup Kevin, this is the Seyco dust collector I have. I love it!! I had them provide a drill chuck on the right side of the grinder so I can use my 3M sanding disks with 1/4" shank. Brian kmmcrafts and OCtoolguy 2 Quote
kmmcrafts Posted November 13, 2020 Report Posted November 13, 2020 Okay, I was talking about the scroll saw dust collector.. that works well for bottom side but nothing for the top.. and not sure it has the power to add on a top side collection hose.. this is the vac I am using https://www.seyco.com/dv-10a-cyclonic-action-scroll-saw-dust-collector/ OCtoolguy 1 Quote
