Recipe one Posted November 29, 2020 Report Posted November 29, 2020 Hello Everyone Does any one know if you can get an adaptable variable speed control box to use separately with a Multimax Hegner scroll saw. Any help appreciated OCtoolguy 1 Quote
Rockytime Posted November 29, 2020 Report Posted November 29, 2020 I'm not an expert but I use a HF router speed control on most of my equipment that is powered by a motor that uses brushes. Just a suggestion. kmmcrafts and OCtoolguy 1 1 Quote
Recipe one Posted November 29, 2020 Author Report Posted November 29, 2020 Hi Rockytime Thanks for the information appreciated I was interested in a 14" Multimax but I wonder if you can use an adaptable speed control box too slow it down enough . have more control over whether it would work right? or is it not worth it better off buying one that already has it built into the equipment such as an 18" Multimax OCtoolguy 1 Quote
Rockytime Posted November 29, 2020 Report Posted November 29, 2020 My 14" is variable speed. Is yours belt driven? OCtoolguy 1 Quote
Recipe one Posted November 30, 2020 Author Report Posted November 30, 2020 Hi Rockytime This is one I found on Ebay all it said was Multimax 2 14" seemed to be a good price but looked like a single speed for the pic's I would like to able to cut slow more control build confidence in working with a good quality scroll saw . OCtoolguy 1 Quote
Rockytime Posted November 30, 2020 Report Posted November 30, 2020 Then I would try the router speed control. Important to know what kind of motor it has. OCtoolguy 1 Quote
rash_powder Posted November 30, 2020 Report Posted November 30, 2020 I am pretty sure Hegner uses capacitor start motors like what are found in furnaces, air conditioners, etc. These motors use a variable frequency drive to control there speed correctly. The router speed controls are generally variable voltage. Its been a while since I looked into all this; but that router control will likely limit the power of the saw. Rockytime and OCtoolguy 2 Quote
stoney Posted November 30, 2020 Report Posted November 30, 2020 (edited) I'm not an electric motor expert but Hegner uses an induction motor on their scroll saws. Motors with brushes are called universal motors and their variable speed controllers are not designed the same. Edited November 30, 2020 by stoney OCtoolguy and Rockytime 2 Quote
Recipe one Posted November 30, 2020 Author Report Posted November 30, 2020 Hello Everyone Thank you for all your input appreciated, adding a speed control box to a single speed scroll saw setup? sounds like maybe it would be best to look for one that already has it built into the machine, than to find out it does not perform properly, with the machine you just purchase- adding a speed control box The last thing I want is a saw that is too fast and aggressive, have to try to get use to the fact that it has no other speed option for cutting intricate parts out. I have never owned a good quality scroll saw for though that do once comfortable with the saw and how it is design to cut material , question how accurate can you cut parts out with a top of the line saw like a Hegner scale model building . Any additional help would be appreciated OCtoolguy 1 Quote
Recipe one Posted November 30, 2020 Author Report Posted November 30, 2020 Scale wood model building Quote
OCtoolguy Posted November 30, 2020 Report Posted November 30, 2020 1 hour ago, Recipe one said: Hello Everyone Thank you for all your input appreciated, adding a speed control box to a single speed scroll saw setup? sounds like maybe it would be best to look for one that already has it built into the machine, than to find out it does not perform properly, with the machine you just purchase- adding a speed control box The last thing I want is a saw that is too fast and aggressive, have to try to get use to the fact that it has no other speed option for cutting intricate parts out. I have never owned a good quality scroll saw for though that do once comfortable with the saw and how it is design to cut material , question how accurate can you cut parts out with a top of the line saw like a Hegner scale model building . Any additional help would be appreciated As accurate as you want it to be. It's mostly in the operator more than the saw. If you stick with one of the top names, not the entry level saws, you'll be fine. I turn the speed down on mine occasionally but most of the time I leave it about 2/3 throttle. The key word here, no matter what saw you decide on, is PRACTICE! Don't jump in and think you'll be an expert right off. Get some thin plywood and just scribble some patterns on that and cut away. Lot's of "how to" videos on youtube. stoney 1 Quote
Recipe one Posted December 2, 2020 Author Report Posted December 2, 2020 Hello SSV Patron Thank you for the information and advice appreciated,Question as I was trying to educate myself a bit more here board thickness and cutting on a scroll saw . I have one project I was trying to do that requires a board thickness of 3/4 but I read somewhere that scroll saws are design to hand a max of 1/4 ? choose of material to work with would be Alder the softest of the hardwoods just above pine and poplar . Any additional help would be appreciated OCtoolguy 1 Quote
NC Scroller Posted December 2, 2020 Report Posted December 2, 2020 I am not sure where you saw scroll saws are designed for a max of 1/4" but I cut wood often up to 1 1/2" (38mm) thick on my scroll saw. 3/4" is really a standard for many projects. Even those of us who stack cut will typically stack 3/4" or more. Now thicker woods do require larger blades. Typically I would use a 2/0 or #1 blade on 1/4" or less and a #5 or #7 on 3/4" or more. For a newbie I would recommend poplar. Pine is softer but the pronounced grain in pine can cause blade control issues as the blade will tend to follow the grain. OCtoolguy 1 Quote
Recipe one Posted December 4, 2020 Author Report Posted December 4, 2020 Hi Scott Thank you for the information appreciated, encouraging news board thickness that a scroll saw is designed to handle up too great ! I have one more question when looking at the older model Hegner's vs the new models, I did notes that the new models have a throat plate insert, while the older ones I have seen do not have this design option? is there a the big advantage to having the plate can the work piece get snagged when cutting on one that does not have this design feature . any help appreciated OCtoolguy 1 Quote
NC Scroller Posted December 4, 2020 Report Posted December 4, 2020 1 hour ago, Recipe one said: Hi Scott Thank you for the information appreciated, encouraging news board thickness that a scroll saw is designed to handle up too great ! I have one more question when looking at the older model Hegner's vs the new models, I did notes that the new models have a throat plate insert, while the older ones I have seen do not have this design option? is there a the big advantage to having the plate can the work piece get snagged when cutting on one that does not have this design feature . any help appreciated Not sure what you mean by throat plate. There is a slot from the front of the table to the blade hole slot that is used for ease of blade changes but there is no removable insert like on a band saw or table saw. Do you have a picture? OCtoolguy 1 Quote
Scrappile Posted December 4, 2020 Report Posted December 4, 2020 @NC Scroller The later models of Hegners have a round hole in the table where the blade goes through as opposed to the rectangular holes in the early models. It comes with a metal insert that reduces the size of the hole and you can buy plastic replacement inserts that you drill the size hole you want for the blade to actually go through... Give you options for zero clearance inserts for less tear out.. I make my own inserts for my saw. OCtoolguy and NC Scroller 2 Quote
Recipe one Posted December 4, 2020 Author Report Posted December 4, 2020 Hello Scrappile Thank you for the information appreciated it is not a problem to design one to fit the rectangular hole on the older models yes ? if so what material do you use to make yours up is it some sort of plastic . Thanks Quote
OCtoolguy Posted December 4, 2020 Report Posted December 4, 2020 3 hours ago, Recipe one said: Hi Scott Thank you for the information appreciated, encouraging news board thickness that a scroll saw is designed to handle up too great ! I have one more question when looking at the older model Hegner's vs the new models, I did notes that the new models have a throat plate insert, while the older ones I have seen do not have this design option? is there a the big advantage to having the plate can the work piece get snagged when cutting on one that does not have this design feature . any help appreciated Mine didn't have the removable plate but I never found any problem with that. The old fix is to tape a playing card over the hole to get a zero clearance cutting area. Quote
Scrappile Posted December 4, 2020 Report Posted December 4, 2020 (edited) 18 minutes ago, Recipe one said: Hello Scrappile Thank you for the information appreciated it is not a problem to design one to fit the rectangular hole on the older models yes ? if so what material do you use to make yours up is it some sort of plastic . Thanks Sorry, David,,, I can't answer your question I have never been around an older Hegner.... Maybe @octoolguy answered it... I have an "auxiliary" table top on mine,,, just to make the table a little bigger.. You can see my top is getting somewhat worn.... will have to make a new one one of these days.My table top is Masonite... Work great.. I salvaged the Masonite from an old baby crib.... I have enough left for one more top... Edited December 4, 2020 by Scrappile OCtoolguy 1 Quote
NC Scroller Posted December 4, 2020 Report Posted December 4, 2020 2 hours ago, Scrappile said: @NC Scroller The later models of Hegners have a round hole in the table where the blade goes through as opposed to the rectangular holes in the early models. It comes with a metal insert that reduces the size of the hole and you can buy plastic replacement inserts that you drill the size hole you want for the blade to actually go through... Give you options for zero clearance inserts for less tear out.. I make my own inserts for my saw. Learn something new every day.....Thanks Scrap. OCtoolguy 1 Quote
