Popular Post FrankEV Posted December 1, 2020 Popular Post Report Posted December 1, 2020 This is a H. Botas pattern that I slightly modified to suit a 11X14 panel. The cut panel is 1/8" BB Plywood, left natural, affixed to a 1/4" Mahogny solid core plywood backer that was darkened with Minwax Mahogny stain to improve contrast. Cutting was done with Pegas #0 and #1 spiral Blades. The finished panel was finished with Clear Gloss Spray Lacquer. The panel is set loose in a simple custom made poplar frame that was also stained with the same Minwax Mahogny stain and protected with Clear Gloss spray Polyurethane. OzarkSawdust, Charlie E, amazingkevin and 15 others 18 Quote
OzarkSawdust Posted December 1, 2020 Report Posted December 1, 2020 Awesome job Frank!! Nice choice of woods, and I really like the way you brought out the contrast. Poplar frame stained Mahogany...very nice, I'll have to try that combination. You did the whole thing with those evil spirals! Wow, I can never get the smooth lines with spirals...great job. FrankEV 1 Quote
FrankEV Posted December 1, 2020 Author Report Posted December 1, 2020 3 hours ago, OzarkSawdust said: Awesome job Frank!! Nice choice of woods, and I really like the way you brought out the contrast. Poplar frame stained Mahogany...very nice, I'll have to try that combination. You did the whole thing with those evil spirals! Wow, I can never get the smooth lines with spirals...great job. Thanks for the comments. So JFYI: Unlike Pine and most other wood, Poplar takes almost any color stain verey well because the grain is very uniform and has very little pitch/sap. It also paints up well also. I'm getting to a point that I do not like using regular straight cutting blades. A lot of portrait work lends itself to the use of Spiral blades and cutting time is significantly reduced using them. A lot of practice is the key. For longer straight or curved cuts it is definately dificult to get a smooth cut with a spiral blade, but I have found if I tend to err on the waste side of the line, I can clean the cut up using a shaving action that is possible with a spiral blade. I actually find this technique is often more forgiving than when using a straight cutting blade for similar cuts. Norm Fengstad, amazingkevin and OzarkSawdust 3 Quote
dgman Posted December 1, 2020 Report Posted December 1, 2020 Great looking project Frank! I love the Mahogany backer. I’ve cut many portraits with a natural wood backer. To me, it looks more natural than a painted backer. FrankEV 1 Quote
OzarkSawdust Posted December 1, 2020 Report Posted December 1, 2020 3 hours ago, FrankEV said: Thanks for the comments. So JFYI: Unlike Pine and most other wood, Poplar takes almost any color stain verey well because the grain is very uniform and has very little pitch/sap. It also paints up well also. I'm getting to a point that I do not like using regular straight cutting blades. A lot of portrait work lends itself to the use of Spiral blades and cutting time is significantly reduced using them. A lot of practice is the key. For longer straight or curved cuts it is definately dificult to get a smooth cut with a spiral blade, but I have found if I tend to err on the waste side of the line, I can clean the cut up using a shaving action that is possible with a spiral blade. I actually find this technique is often more forgiving than when using a straight cutting blade for similar cuts. I've been painting my Poplar frames mostly. But I think I'll try the Mahogany stain on one real soon. I just need to use a smaller pattern that I don't care if it comes out and practice with the spirals. I'm sure I have #1s and may have some 0s also. FrankEV 1 Quote
Rockytime Posted December 1, 2020 Report Posted December 1, 2020 Very nice work. I like it! FrankEV 1 Quote
Foxfold Posted December 1, 2020 Report Posted December 1, 2020 Must admit I tried this pattern when my saw was out of action, but seeing yours I think I may have to try it on my saw. I did this one with my router but it pales into insignificance compared to a 'good' cut piece.. OzarkSawdust and FrankEV 2 Quote
Dragonkort Posted December 2, 2020 Report Posted December 2, 2020 fantastic!! i use both regular and spiral blades....like you said it just takes pratice. FrankEV 1 Quote
wombatie Posted December 2, 2020 Report Posted December 2, 2020 Fabulous. You did a terrific job. Marg FrankEV 1 Quote
Charlie E Posted December 2, 2020 Report Posted December 2, 2020 Great looking piece. I love Kingfishers. My Father-in-law hates them as they steal fish from his pond. FrankEV 1 Quote
amazingkevin Posted December 6, 2020 Report Posted December 6, 2020 On 12/1/2020 at 12:34 PM, FrankEV said: Thanks for the comments. So JFYI: Unlike Pine and most other wood, Poplar takes almost any color stain verey well because the grain is very uniform and has very little pitch/sap. It also paints up well also. I'm getting to a point that I do not like using regular straight cutting blades. A lot of portrait work lends itself to the use of Spiral blades and cutting time is significantly reduced using them. A lot of practice is the key. For longer straight or curved cuts it is definately dificult to get a smooth cut with a spiral blade, but I have found if I tend to err on the waste side of the line, I can clean the cut up using a shaving action that is possible with a spiral blade. I actually find this technique is often more forgiving than when using a straight cutting blade for similar cuts. I don't like to shave if possible but it happens. Just today the blade was way to thin and wanted to wander so rather than shave or do it twice i uped the blade size! Quote
